Power series to find the inverse of any function in Z_2[x]?
In summary, the conversation discusses the use of power series in finding the inverse of a function in Z_2[x]. It is pointed out that power series do not make sense in this context unless there are only finitely many nonzero coefficients. The discussion then shifts to the concept of multiplicative inverse and the question of whether elements in Z_2[x] have such inverses in the ring theoretic sense. The conversation also touches on the difference between polynomials and power series, and how power series are not in the ring of polynomials unless they have finitely many nonzero coefficients. The conversation ends with a question about the definition of polynomial rings and a clarification that power series are not in rings of polynomials.
Treadstone 71
275
Is it possible to use power series to find the inverse of any function in Z_2[x]?
Things in Z_2[x] aren't (necessarily) functions (on anything), they are polynomials in one indeterminate. (Ie power series don't even make sense, unless there are only finitely many nonzero coefficients, ie it is a polynomial)
What makes you think that any element in there, except 1, has a multiplicative inverse, purely in the ring theoretic sense?
Exercise, let f be a poly in Z_2[x], and let df denote its degree, show d(fg)=df.dg
1-x is invertible as a power series, I am told.
The original post didn't say anything about multiplicative inverse, just inverse. I would have been inclined to assume that "inverse function" was meant. In that sense, the inverse of 1- x (which equals 1+ x in Z_2[x]) would be itself: 1+ x.
But to consider these as functions is a little odd since it mentions not the domain or range of what they are functions from or to. Since this is posted in the abstract algebra section I think I made prefectly sensible inferral.
The point still holds that speaking of power series in a ring of polynomials is not valid whatever the situation is.
If the question was when can we find polynomials f and g such that f(g(x))=g(f(x))=x then obviously only degree one polys will suffice, and either of those is self inverse under composition in this sense.
Why are power series not in the ring of polynomials? Specifically, a ring of polynomials mod some constant.
Because by definition polynomials only have with finitely many nonzero coefficients, power series may have infinitely many non-zero coefficients.
Ie
1+x+x^2+...
isn't a polynomial so isn't in the ring of polynomials; it's just a definition.
Certainly a polynomial is a power series, but a power series is not in general a polynomial.
I'm not sure why i feel the need to point this out, but for hallsofivy: since the original question asked about using power series to find inverses of things in Z_2[x] (things that are not functions) i felt that the intention was to compute (1+x)^{-1} the multiplicative inverse since it mentioned power series. of course if we were thinking of the space Z_2[x] mod x^n then of course the idea of using power series 'works' since x^n is nilpotent. when i say 'works' i of course mean can be used to construct the answer since the formal power series 1+x+x^2+.. terminates. upon applying mod x^n
As for the other idea of invese: I'm not sure what it means, even if we think of functions on C, to use power series to find the inverse function of f(z)=1+z,or rather I'm not sure why you'd do that.treadstone: could you perhaps clear up this mystery. did you intend to work out (1+x)^{-1} (which doesn't exist in Z_2[x]) or the polynomial (I cannot and will not call them functions) g(x) such that g(1+x)=x.Incidentally, note that if you are considering functions from Z_2 to Z_2 that there are exactly 4 of these, whereas there are infinitely many polynomials in Z_2[x]
Initially, I thought for some reason that Z2[x] is a field. I've seen on an assignment somewhere that any polynomial has a multiplicative inverse written in the form of a power series. I didn't have any idea why power series aren't in the ring of polynomials. I mean, if Z2[x] didn't contain any polynomials, then it should be finite in cardinality. However it isn't, since for any poly of degree n, one can always write down one of degree n+1. This was all for an extra credit question on the final so I didn't have time to think it all the way through.
Anyway, I had to show that there are no surjective homomorphisms between Z2[x] and Z2XZ2XZ2. By assuming that any element in Z2[x] has a multiplicative inverse written as some power series, I showed that the kernel of any homomorphism between those two rings must be 0, and therefore the homomorphism must be injective. With the additional hypothesis that the hypothesis that it is also surjective, there would be an isomorphism between Z2[x] and Z2 X Z2 X Z2, which is impossible. It's a proof by contradiction, basically.
Unfortunately I didn't know that A) power series aren't in rings of polynomials (though I find this odd) and B) therefore Z2[x] is not a field.
Maybe taking a step back would be a good idea:
What is the definition of "polynomial"? Of "power series"? Of the ring "R[x]" (where R is a commutative ring)?
If Z_2[x] were a field then of course there is no hom from it to (Z_2)^3 since any ring hom from a field is either an injection or an isomorphism, both of which are impossible for cardinality reasons in this case (ie we can remove the hypothesis that the notional map is surjective).
I said it didn't make sense to talk about power series. Whilst a poly is a power series, you cannot blithely talk about power series in Z_2[x] unless you check it only has finitely many non-zero coefficients, ie it is a polynomial.
well, it is just a definition. look up the definition of polynomial.
http://mathworld.wolfram.com/Polynomial.html
It doesn't say explicitly about finite power.
But here's my argument: elements in Z2[x] are of the form a+bx+cx^2+...+zx^n where the coefficients are 0 or 1. But the cardinality of the ring is infinite! i.e., the highest power (degree) can be made ARBITRARILY large. That's pretty much like an infinite series, isn't it? For if m is the highest degree in Z2[x], then there are only 2^m elements in Z2[x].
Look at their general form for a polynomial, eq. (1). It is a sum with n terms. It has a first and a last term. Both of these are giant flags saying "finite number of terms", even if they aren't mentioning it explicitly.
A polynomial has a finite number of terms, that's how they are defined.
Z_2[x] has polynomials of as high a degree as you like. This is not the same as saying you have a polynomial with "infinite degree". The polynomials 1, x, x^2, x^3, x^4, ... are all in Z_2[x], but none of them has an infinite number of terms.
I somehow suspect your book didn't define polynomials by saying "Go look at Mathworld's page". :smile:
In some sense, yes. But in a more practical sense, certainly not.
There is a huge difference between "arbitrarily large" and "infinite", though the difference is subtle at first. The term "arbitrarily large" necessarily refers to some class of objects (such as the collection of polynomials over Z_2), where as "infinite" is generally applied to a single object (such as the list of coefficients of a power series).
Well then, goodbye 20 marks:frown:
FAQ: Power series to find the inverse of any function in Z_2[x]?
What is a power series and how does it work in finding the inverse of a function in Z_2[x]?
A power series is a mathematical series that is written in the form of a polynomial. It is used in finding the inverse of a function in Z_2[x] by representing the function as a polynomial and then using algebraic operations to find its inverse.
Can any function in Z_2[x] have an inverse using power series?
No, not all functions in Z_2[x] have an inverse. The function must be bijective (one-to-one and onto) in order for it to have an inverse. This means that each element in the domain has a unique element in the range and vice versa.
How do you determine the power series for a given function in Z_2[x]?
The power series for a function in Z_2[x] can be determined by using the Taylor series expansion. This involves finding the derivatives of the function at a specific point and plugging them into the formula for the Taylor series.
Are there any limitations or restrictions when using power series to find the inverse of a function in Z_2[x]?
Yes, there are limitations when using power series to find the inverse of a function in Z_2[x]. The function must be continuous and differentiable at the point where the inverse is being calculated. Additionally, the function must have a non-zero derivative at that point.
How accurate is the inverse function obtained using power series in Z_2[x]?
The accuracy of the inverse function obtained using power series in Z_2[x] depends on the number of terms used in the series. The more terms used, the more accurate the inverse will be. However, it is important to note that power series are only accurate within a certain radius of convergence, and outside of this radius, the inverse may not be accurate.
