Powering motor with boost converter?
In summary, the conversation is about trying to increase the fan speed of a blower motor from 12V to 20V. The speaker is planning to use a BC with a 555 and has calculated the necessary component values. However, they are unsure if they can find components that can handle the high current requirements. Other suggestions are given, such as using a higher voltage diode or looking into switcher ICs. The speaker admits to not being an expert in this area and is seeking advice on how to properly design the BC.
neuroclast
Hi. I have a blower motor I am trying to run at 20v from a 12vdc system. At 12v it draws 12A, but I need it to get to a higher RPM. I'm not sure what the surge current is (turning on). Anyway, I was talking to someone else and they didn't think increasing the voltage with a BC would increase the fan speed.
I have planned to try and make a BC w/a 555 and see how it runs. The calculations I got for the BC parts @ 77KHz:
Inductor 1.05 uH / 65A
130uF cap
22V 65A diode
SO yeah those are pretty huge current values. I'm not sure if I can even find a 65A components. Is there another way to do this that I might be missing?
Thanks!
130uF cap
22V 65A diode
Thanks!
Use a diode with a higher voltage rating. 22v is way too close to your target output voltage.
What is your feedback regulation scheme? Have you looked at using the National Semiconductor Simple Switcher series of ICs?
And what are you planning on using for the switch transistor?
I looked at those Switcher ICs, but it appears none support anywhere near my needed output current. As for the transistor I hadn't picked one yet, I was waiting to see if anyone had better ideas that I hadn't thought of to get this motor to 20V.
The switcher ICs are meant to be used as a basis. The data sheets should show how to configure transistors and such to boost the current capabilities of the power supply. Don't listen to whoever told you that increasing voltage with a BC would not increase fan speed. Although it may not be an easy task to do so, once the voltage is at 20 volts the fan speed should definitely be faster than at 12 volts. 20 volts is 20 volts.
Hrm, if there is a way to boost them past the 5v then I don't see how given the inductors are internal on those ICs. I will freely admit I am about as far from an expert on these things as one can be however. Haven't even started my EE classes yet :]
I have made a 12v->400v BC before for charging caps, but never anything high current. That's really why this is so foreign to me. I can get the 555 circuit setup easy enough, and I understand the building blocks for the BC, but the only way I know to get the component values are online calcs. I may be doing those wrong for all I know.
Basically I just need this 12A@12VDC motor to be supplied 20VDC. As for the inductor max current/saturation current/inductance and that stuff I am completely in the dark. I am wondering if maybe those kind of current requirements are impractical for a BC?
No, the inductor is not inside any IC. As supernova says, the DC-DC controller ICs generally have a low-current switching transistor inside them, but can be configured to use an external power transistor for higher current applications. You should be able to do some reading at the National Semiconductor website to learn all about how Boost Converters work, and where the design equations come from.
FAQ: Powering motor with boost converter?
1. How does a boost converter work to power a motor?
A boost converter is a type of DC-DC converter that steps up the input voltage to a higher output voltage. It works by using an inductor to store energy from the input voltage and then releasing it to the output in short bursts. This allows for a higher output voltage than the input voltage.
2. What are the advantages of using a boost converter to power a motor?
One of the main advantages of using a boost converter is its ability to provide a higher output voltage than the input voltage. This is useful for powering motors that require a higher voltage than the available power source. Additionally, boost converters are efficient and have a small size and lightweight design, making them ideal for portable applications.
3. Can a boost converter be used to power different types of motors?
Yes, a boost converter can be used to power various types of motors, including DC motors, stepper motors, and brushless DC motors. However, the specific requirements for each type of motor, such as voltage and current, must be taken into consideration when selecting a boost converter.
4. How do I choose the right boost converter for my motor?
When choosing a boost converter for a motor, there are several factors to consider. These include the input voltage of the power source, the required output voltage and current for the motor, and the efficiency and size of the boost converter. It is recommended to consult with a specialist or refer to the manufacturer's specifications to determine the most suitable boost converter for your motor.
5. Are there any safety precautions to consider when using a boost converter to power a motor?
Yes, it is essential to follow safety precautions when using a boost converter to power a motor. This includes ensuring that the input voltage does not exceed the maximum rating of the boost converter, properly grounding the circuit, and protecting against short circuits. It is also important to use a boost converter with overvoltage and overcurrent protection to prevent damage to the motor and other components.
14K
