Poynting vector power flow question
In summary: I am wrong about any of this!In summary, the equation for calculating electromagnetic power flow is wrong. The Poynting vector should be \frac12 \Re \{ \vec E \times \vec H^* \}
JamesGoh
143
Im aware that the complex electromagnetic powerflow from a solid is described by the poynting vector (see 1.1), however I am not sure how the 1/2 term arises in the formula
[tex]1/2\oint\vec{E} \times \vec{H}.ds[/tex] (1.1)
where [tex]\times[/tex] = vector cross product and ds denotes a variance in the surface of the object
From the textbook I read, it says that [tex]\vec{E}[/tex] and [tex]\vec{H}[/tex] are peak phasors, not RMS which is meant to explain the 1/2 term, but from my understanding, the Vrms of a sinusoidal is always Vpeak/sqrt(2) where Vpeak = peak voltage of sinusoid. So I am really confused
Can anyone help me out here ?
cheers
E and H each get divided by sqrt{2}, so their product is divided by 2.
Ok I get the maths, but why is the E and H vectors divided by sqrt(2) ? In calculating electromagnetic power flow, are we only interested in the effective power being emitted from a solid ?
The equation is wrong. The Poynting vector should be
[tex]\frac12 \Re \{ \vec E \times \vec H^* \}[/tex]
That is, with the complex conjugate of H. This expression gives the real power emitted (hence the real part being taken). The imaginary part gives the reactive power, which is not part of the net energy transfer.
The factor of 1/2 comes because we are using complex phasors to represent real fields by means of
[tex]\vec E_{\textrm{real}} = \Re \{ \vec E (\cos \omega t + i \sin \omega t) \}[/tex]
Therefore, every phasor field actually represents two oscillatory fields superimposed over each other, 90 degrees out of phase. Thus when we calculate the power or intensity, we will overshoot by a factor of 2.
Ok how do you obtain the 2 mathematically ?
Is it from realising that
cos(theta) = [exp(j*theta) + exp(-j*theta)] /2
sin(theta) = [exp(j*theta) - exp(-j*theta)] / (2*j)
Or that when you integrate a cos(theta)^2 term you end up with a 1/2 constant in your result ?
Note j = i
Cos^2(theta) + Sin^(theta) = 1
So the time average of Cos^2(theta) must be 1/2.
Thats all there is to the 1/2.
Note: Cos^2(theta) is the same as Cos(Theta)^2
All right, to show my understanding of this concept, I just want to run some things through with everyone
1) We take the real part of E x H divided by a half since practically, we are interested in the real power, not the reactive power
2) The reason for dividing by 2 arises from the fact that the E or H field consists of 2 sinusoidal components and the definition of power being the average energy over a period of time
3) the cos^2(theta) is a mathematical product of the E x H cross product operation
Please feel free to correct me
FAQ: Poynting vector power flow question
What is the Poynting vector?
The Poynting vector is a mathematical quantity that represents the direction and magnitude of electromagnetic energy flow in a given space. It is named after its discoverer, John Henry Poynting.
How is the Poynting vector calculated?
The Poynting vector is calculated by taking the cross product of the electric field and magnetic field vectors at a specific point in space. It is represented by the formula S = E x B, where S is the Poynting vector, E is the electric field, and B is the magnetic field.
What is the significance of the Poynting vector?
The Poynting vector is an important concept in understanding the propagation of electromagnetic waves. It helps us to visualize and calculate the energy transfer from a source to its surroundings, and can be used to determine the intensity and direction of electromagnetic radiation.
How does the Poynting vector relate to power flow?
The Poynting vector is directly proportional to the power flow of an electromagnetic wave. This means that the larger the Poynting vector, the more energy is being transferred through a given area, and therefore the higher the power flow.
Can the Poynting vector be negative?
Yes, the Poynting vector can have a negative value. This occurs when the electric and magnetic fields are oriented in opposite directions, resulting in a negative cross product. This indicates that the energy flow is in the opposite direction of the vector's orientation.
