Pp total cross section and asymtotic freedom
In summary, the conversation discusses the total cross section of proton-proton collisions at high energies. The data shows a slight increase in the cross section, which is not well understood. Some models suggest that the finite size of the proton determines the cross section, while others suggest that the parton distribution functions (PDFs) and multi-parton interactions play a role. However, fundamental laws of physics and the concept of Pomerons cannot fully explain the observed increase in the cross section. The conversation also compares the data to the electron-proton scattering data, which shows a decrease in the total cross section at high energies. This discrepancy cannot be explained by QCD's "asymptotic freedom."
gtoeroe
Hi!
On page 12 of http://pdg.lbl.gov/2009/reviews/rpp2009-rev-cross-section-plots.pdf one can see the total cross section increasing beyond a certain treshold. At higher energy protons (and their quarks) have a shorter wave length and so they can become closer an closer and the strong force should become smaller and smaller. Then the cross section should decrease. Where is my mistake?
gtoeroe
Protons have a substructure and a finite size. The roughly flat cross-section over a large energy range is just something like the geometric size of the protons.
The cross-section for events like "half the collision energy ends up as transverse energy" goes down, but you get more and more collisions with small momentum exchange relative to the collision energy - and the PDFs rise quickly if you go to smaller x.
The small rise is not well understood, and there are multiple ideas, but that is a small effect.
Likes nrqed
Well, the increase within the curve is small, but compared to what one would expect it is not small. If one interprets "asymptotic freedom" as "vanishing interaction at high energy" then a decrease like in the coulomb range should be expected. So we have something here what QCD can't explain?
What you would expect from the model "the proton has a finite size which determines the cross-section" is a flat line.
What you would expect from the model "we have PDFs as function of x and Q^2, and integrate the cross-sections starting from some minimal momentum exchange" is not far away from a flat line if you take care of multi-parton interactions (otherwise it is rising with energy).
It is hard to get the exact shape with QCD without any experimental input, but it is easy to get a reasonable approximation, and the remaining difference is probably just our lack of knowledge about nonperturbative QCD.
Relevant concept: Pomerons
What you would expect from the model "we have PDFs as function of x and Q^2, and integrate the cross-sections starting from to some minimal momentum exchange" is not far away from a flat line if you take care of multi-parton interactions (otherwise it is rising with energy).
There is no doubt that the calculation of a strongly interacting process is a very difficult assignment. However, even without doing such calculations one can apply fundamental laws of physics and derive conclusion pertaining to hadronic structure. Below are a few points that are relevant to the proton-proton scattering data depicted on p. 11 of http://pdg.lbl.gov/2012/reviews/rpp2012-rev-cross-section-plots.pdf (hereafter, these data are called “the p-p data”):
1. The data of electron-proton scattering prove that for high energy the process is described as a collision of the electron with a single quark. This property holds even for the energy which was available nearly 50 years ago. The term Deep Inelastic Scattering describes this process. See e.g. https://en.wikipedia.org/wiki/Deep_inelastic_scattering.
2. The electron-proton high energy scattering data show that the total cross-section decreases with increasing energy (see e.g. the Rosenbluth formula) and that for a heavy collision, the portion of elastic cross-section decreases even faster. Therefore, the data of electron-proton scattering is completely different from that of the p-p data, where, at very high energy, both the elastic and the total cross-sections increase.
3. Fundamental wave properties indicate that as the projectile’s energy increases and its associated wave-length decreases, the effective scattering region decreases. This is the reason for the decrease of the electromagnetic electron-proton cross-section. Therefore, unless new dynamical factors arise or the interaction near the origin grows much faster than 1/r, the total cross-section should decrease with an increasing scattering energy.) This is a general scattering property of every quantum particle. On top of that, one should also note that QCD’s “asymptotic freedom” means that the quark-quark interaction practically vanishes at small distance. It follows from QCD that the proton-proton scattering cross-section should decrease much faster than the electron-proton cross-section. This QCD result is completely inconsistent with the p-p data.
This is a formula for elastic scattering, and with electron/proton collisions instead of proton/proton collisions so you would not expect the same result. Also, where did you integrate it over all phase space?
This argument is faulty as it ignores the proton PDFs and the minimal momentum exchange to be considered a collision. At high energies you have more particles in the proton that can contribute to a collision.
The coupling goes down for higher energies, but that just means the cross-section for jets with 1/4 the proton energy (random example) goes down. So what, that's not the total cross-section.
Related to Pp total cross section and asymtotic freedom
1. What is the Pp total cross section and why is it important?
The Pp total cross section is a measure of the probability that a proton and antiproton will interact and produce new particles. It is important because it helps us understand the fundamental forces that govern the interactions between particles at high energies.
2. How is the Pp total cross section related to asymptotic freedom?
The Pp total cross section is related to asymptotic freedom through the strong nuclear force. Asymptotic freedom is a property of this force that describes how the force weakens at very short distances. The Pp total cross section decreases as the energy of the particles increases, which is a direct consequence of asymptotic freedom.
3. Can you explain the concept of asymptotic freedom in simple terms?
Asymptotic freedom is the phenomenon where the strong nuclear force becomes weaker at very short distances. This means that at high energies, particles can get closer together without experiencing a strong repulsion. It allows us to understand and predict the behavior of particles at extremely small scales.
4. How do scientists measure the Pp total cross section?
Scientists measure the Pp total cross section by colliding protons and antiprotons at high energies and observing the particles that are produced. By analyzing the data from these collisions, they can calculate the probability of proton-antiproton interactions and determine the Pp total cross section.
5. What are the practical applications of understanding the Pp total cross section and asymptotic freedom?
Understanding the Pp total cross section and asymptotic freedom has practical applications in fields such as particle physics, astrophysics, and cosmology. It allows us to study the fundamental building blocks of the universe and how they interact. This knowledge can also help us develop new technologies and advance our understanding of the universe.
9K
  • Beyond the Standard Models
