: precalc project amplitude help
In summary, the project for precalc class explores the applications of sine waves in real life, specifically bat and dolphin echolocation. The provided information includes frequency in Hz, length of pulse, and intensity in dB. However, the amplitude is incorrect and needs to be solved. The provided intensity range is not actually an intensity, but a logarithmic scale compared to a standard intensity. Additionally, amplitude is a problematic quantity and may not be useful for this study.
egan94
URGENT: precalc project amplitude help!
I am doing a project for my precalc class which explores the applications of sine waves in real life. I chose to do bat and dolphin echolocation. so far the information i have found online has given me frequency in Hz, length of each pulse, and intensity in db. I'm pretty sure that the frequency and periods are correct but I am almost positive that my amplitude is wrong. Please help! I have been working on this all day and the project is due tonight at 9!
the numbers for bats are:
Bat frequency: 14,000-100,000Hz
Each pulse last .2-100 milliseconds
intensity= 60-110 db
dolphins:
Click duration: 50 to 128 microsecond
Travels at 1.5 km/sec
Frequency: 2,000 to 150,000 Hz
Intensity: 150 dB
my calculations for bats:
Frequency: 14,000 Hz
period= 1/frequency= 2π/b
2π/b=1/14,000
b=28,000π
Amplitude: intensity=60 to 110db
110-60=50db
Vertical shift up 50 since intensity can’t be less than zero
Y=asin(bt+c)
Y=50sin(28,000π)+50
how do i solve the amplitude with the information i have gathered?
I don't have the answer, but perhaps can shed some light on the problem.
The 110 db you have is not an intensity (which would have units of watts per square meter) but rather a logarithmic scale of how much more intense this sound is compared to some standard intensity. Check this link: http://en.wikipedia.org/wiki/Sound_intensity#Sound_intensity_level
you could use its standard intensity to convert your db value into an intensity. Check the links at the bottom of the article - this one gives all kinds of conversion formulas (but none for amplitude):
http://www.sengpielaudio.com/RelationshipsOfAcousticQuantities.pdf
Amplitude is more problematical. Amplitude of what? It could be the pressure of the sound wave. Or maybe the displacement of the medium as the wave passes through:
The amplitude of sound waves and audio signals (which relates to the volume) conventionally refers to the amplitude of the air pressure in the wave, but sometimes the amplitude of the displacement (movements of the air or the diaphragm of a speaker) is described. The logarithm of the amplitude squared is usually quoted in dB, so a null amplitude corresponds to −∞ dB. Loudness is related to amplitude and intensity and is one of most salient qualities of a sound, although in general sounds can be recognized independently of amplitude. The square of the amplitude is proportional to the intensity of the wave.
http://en.wikipedia.org/wiki/Amplitude
In short, amplitude probably isn't a useful quantity in your study.
Related to : precalc project amplitude help
1. What is amplitude in precalculus?
Amplitude in precalculus refers to the maximum displacement of a periodic function from its equilibrium position.
2. How do you calculate amplitude?
To calculate amplitude, you need to first find the midline, or the horizontal line that the function oscillates around. Then, measure the distance from the midline to the maximum or minimum point of the function. This distance is the amplitude.
3. What is the difference between amplitude and frequency?
Amplitude and frequency are two different properties of a periodic function. Amplitude refers to the maximum displacement of the function, while frequency refers to the number of complete cycles the function completes in one unit of time.
4. How does amplitude affect the graph of a function?
The amplitude of a function affects the height of the graph. A larger amplitude means a more stretched out graph, while a smaller amplitude means a more compressed graph. The midline of the graph remains the same regardless of the amplitude.
5. Can amplitude be negative?
Yes, amplitude can be negative. This means that the function will be reflected over the x-axis, resulting in a downward facing graph. The absolute value of the negative amplitude is still the same as the positive amplitude, so the height of the graph remains unchanged.
