Precessing electron, probability of spins
In summary, the problem involves an electron precessing in a B field aligned with the +z axis. The spin of the electron at t=0 is in the +x direction and the wave function is given as a matrix. For t>0, we need to find the probability of finding the electron in two different states, one with a specific z-component of spin and the other with a specific x-component of spin. The notation used in the book may be confusing, but it is correct to use |<z|psi>|^2 for the first state and |<x|psi>|^2 for the second state. Your solutions are correct and show a good understanding of the problem.
joex444
44
An electron precesses in B field aligned with +z axis. At t=0, spin of the electron is in the +x direction. Wave function is given as a matrix, but is equal to 1/sqrt(2)[e^-iwt/2 |z> + e^iwt/2 |-z> ]. (Sorry, idk LaTeX). For t>0, find the probability of finding the electron in the state:
(a) ms = +h/2 [h-bar] [m sub s]
(b) msx = +h/2 [h-bar] [m sub sx]
Actually, I just want to make sure I set these problem up right. I have the answers, and I did get the correct answers, but:
for (a): I did |<z|psi>|^2, it came out to 1/2
for (b): I did |<x|psi>|^2, it came out to cos^2(wt/2)
I'm not sure if my setup for (a) was right, or not. I could've got the same result with |<-z|psi>|^2, for example. I'm not sure if its a notation thing with the book, they tend to use msx and msy, but I don't recall seeing msz, perhaps they use the notation that msz = ms. This makes some sense, as there is no such thing as definite total spin, even with just 1 electron.
Thank you for your question. Your setup for part (a) is correct. The notation used in the book may be a bit confusing, but in this case, msz does refer to the z-component of the spin, which is equal to ms. So you were correct to use |<z|psi>|^2 for part (a).
For part (b), your approach is also correct. The notation msx may refer to the x-component of the spin, so using |<x|psi>|^2 is the appropriate approach.
Overall, it seems like you have a good understanding of the problem and your solutions are correct. Keep up the good work!
FAQ: Precessing electron, probability of spins
What is a precessing electron?
A precessing electron is an electron that is in a state of precession, which refers to the spinning motion of an electron around its own axis.
What is the probability of spins in an electron?
The probability of spins in an electron refers to the chance of an electron having a particular spin orientation, either up or down, when measured.
How is the probability of spins in an electron determined?
The probability of spins in an electron is determined by the laws of quantum mechanics, specifically the spin statistics theorem, which states that fermions (such as electrons) can have only half-integer spin values.
Can the probability of spins in an electron be changed?
The probability of spins in an electron cannot be changed, as it is a fundamental property of the electron and is determined by the laws of quantum mechanics.
What is the significance of precessing electrons and their probability of spins?
Precessing electrons and their probability of spins are important in understanding the behavior of atoms and molecules, as well as in the development of technologies such as magnetic resonance imaging (MRI). They also play a crucial role in quantum computing and information processing.
