Precession in Special and General Relativity - Comments
In summary, precession in special and general relativity is the phenomenon where the orientation of a spinning object changes over time due to the effects of gravity and motion. In special relativity, it is caused by the effects of motion, while in general relativity, it is caused by the warping of space and time by massive objects. Precession is important in the study of relativity as it helps to validate predictions and explain the behavior of objects near massive objects. It differs from precession in classical mechanics, which is explained by external forces, and can be observed in everyday life through the changing positions of stars and the behavior of gyroscopes.
Bill_K_Insights
Bill_K submitted a new PF Insights post
https://www.physicsforums.com/insights/precession-special-general-relativity/
In the section "Precession in Flat Space", the velocity and acceleration 4-vectors should be defined as v = Dx / Dτ and a = Dv / Dτ. (The article as it stands has Dt instead of Dτ.) The actual expressions for v and a are correct.
thanks for your post
does the Fermi-Walker transport could be determined by fiber bundle?
Related to Precession in Special and General Relativity - Comments
1. What is precession in special and general relativity?
Precession is the phenomenon where the orientation of a spinning object, such as a gyroscope, changes over time due to the effects of gravity and motion. In special and general relativity, precession is explained by the warping of space and time by massive objects.
2. How does precession occur in special and general relativity?
In special relativity, precession is caused by the effects of motion on the orientation of an object. In general relativity, precession is caused by the warping of space and time by massive objects, such as the sun, which bends the path of objects that are moving near it.
3. Why is precession important in the study of relativity?
Precession is important in the study of relativity because it can be used to test and validate predictions made by the theory. It also helps to explain the behavior of objects in the presence of massive objects, and provides evidence for the existence of black holes.
4. How does precession in general relativity differ from precession in classical mechanics?
In classical mechanics, precession is explained by the effects of external forces on an object's motion. In general relativity, precession is explained by the warping of space and time by massive objects. Additionally, the equations used to calculate precession in general relativity are more complex than those used in classical mechanics.
5. Can precession in special and general relativity be observed in everyday life?
Yes, precession in special and general relativity can be observed in everyday life. For example, the precession of the Earth's orbit around the sun can be observed in the changing positions of the stars in the night sky. Additionally, the precession of gyroscopes on Earth and in space is also a result of the effects of relativity.
