RylonMcknz
- 5
PROBLEM:
HINTS:
ATTEMPT:
Show that Special Relativity predicts a precession of π(GMm/cl)2 radians per orbit for any elliptic orbit under a pure inverse-square force.
where G is gravitational constant, M is mass of larger body, m is mass of smaller orbiting body, c is speed of light and l is angular momentum.
HINTS:
Differential equation for Newtonian inverse-square force orbit: d2u/dθ2 + u = mk/l2 (Eq.1), where u = 1/r, k = GMm.
To make this relativistic: mk→ϒmk, where ϒ = 1/√(1 - (v2/c2)).
Also E = ϒmc2 + U.
Then right side of (Eq. 1) becomes ⇒ϒmk/l2 = (E - U)k/c2l2 = (E + ku)k/c2l2 (Eq. 2).
Precession causes the following change of phase angle (in radians/orbit):
Δθ - Δθ' = 2π/ω - 2π = 2π(1/ω - 1) (Eq. 3).
Also E = ϒmc2 + U.
ATTEMPT:
(Eq. 1) & (Eq. 2) ⇒ d2u/dθ2 + u = (E + ku)k/c2l2
⇒ d2u/dθ2 + u - k2u/c2l2 = Ek/c2l2
⇒ d2u/dθ2 + (1 - k2/c2l2)u = Ek/c2l2,
where ω2 = (1 - k2/c2l2) (Eq. 4),
and let A = Ek/c2l2.
Then substitute y = u - A/ω2.
Then we have d2y/dθ2 + ω2[y + A/ω2] - A = 0
⇒ d2y/dθ2 + ω2y = 0
Solution is then y = y0cos(ωθ - θ0).
I then try substituting (Eq. 4) into (Eq. 3) to find the resulting precession in radians per orbit, but this doesn't not give the desired result. This is where I'm stuck, not sure what I'm doing wrong. Thank you for your considerations.
⇒ d2y/dθ2 + ω2y = 0
