SchroedingersLion
- 215
- 57
Hi guys,
while going through rotational energy levels of molecules, I found myself struggling with a very basic concept.
The concept of precession, in terms of a torque induced rotation of the rotational axis of a spinning rigid body.
Take a glance at the Wikipedia figure:
https://en.wikipedia.org/wiki/Precession#/media/File:PrecessionOfATop.svg
Now suppose that the spinning top has the same position as in the figure, only with 0 gravity.
In 0 gravity, it will keep spinning with angular momentum L for all eternity and will not fall down or perform precession or anything.
Now let's turn on the gravity. This leads to a force on the centre of mass pointing downwards, creating a torque M. This torque leads to a change in angular momentum dL=M*dt with dL being a vector standing orhtogonal on L and pointing in a direction tangential to the circular motion of the top surface at its lowest point.
So L --> L+dL.
What I don't really understand: Who says that the axis of rotation of the top now follows the change in vector L?
If that is the case, everything can keep repeating itself and we get precession.
But I don't see that the top axis necessarily follows the change in L. Can't there be some other physical behaviour?
Or, to put it another way, if there is a body with an L vector given, can I trace back this specific L vector to a well defined and unique rotation? Or are there other possible rotational behaviours possible with the same L?
I am a bit confused.
Regards
So L --> L+dL.
Regards
