Precision measurements of atomic mass.
In summary, the atomic mass of hydrogen is calculated by taking the average mass of the ions that pass through a magnetic field. Converting between different units can help to avoid miscalculations.
Dadface
2,489
105
Hello
I have been trying to find out how the data for the atomic mass of different isotopes is processed. I am vaguely familiar with mass spectrometry and other techniques used for the measurements and I know that the experimental results are coordinated by the Atomic Mass Data Centre.
I am particularly interested in atomic hydrogen but how is the data processed? What measurements are needed and how is the data processed to calculate the mass of hydrogen in, for example, its ground state. I think I know the answer but I would like confirmation.
I have a rather large paper on the subject of mass measurement coordination but I find it a very heavy read and I think it assumes a lot of prior metrological knowledge on the part of the reader.
Thank you.
The data is "processed" by someone looking at it and making notes on paper ... but I suspect that is not what you are after.
The output of a mass spectrometer is usually a wiggly line on a printout or a screen.
Perhaps you want to know how putting ions through a magnetic field ends up as a wiggly line on a screen?
In which case it would help if you described as much of the process as you have figured out so far and we can correct misconceptions, fill in any important gaps, and finish it off for you.
Thank you for your reply,
I'm roughly familiar with with the principle of mass spectrometry and other experimental techniques used but what I want to know is how the results are coordinated. The Atomic Mass Data Centre receive results from a large number of experiments and these are processed by the centre so as to calculate mass data of the type which is published by organisations such as NPL and NIST.
I want to know how the atomic mass of hydrogen is calculated. What raw data for masses is needed and how is this data converted to calculate the mass of the neutral hydrogen atom? I'm fairly confident I know (knew) the answer, and I think it's simple but when I tried to confirm it using, what I assume to be the latest and most precise data available the numbers were close but didn't match, even within the limits of uncertainty.
Oh you want to know how the results from a large number of experiments turns into the official number?
A commitee works out which results to use and how to handle them. Usually there is a standard measurement method that gets decided on.
This is the same for all weights and measures.
If that is not it then perhaps you should show us what you did that did not turn out as you hoped?
Likes Dadface
Thank you again Simon,
I tried the numbers again but this time with the aid of the Nist programme that converted between different energy units. I think I miscalculated the conversions first time round. This time there was the match I expected.
Oh well that would do it - well done :)
FAQ: Precision measurements of atomic mass.
1. What is atomic mass and why is it important to measure it precisely?
Atomic mass is the mass of an atom, which is made up of protons, neutrons, and electrons. It is important to measure atomic mass precisely because it helps us understand the fundamental building blocks of matter and how they interact with each other.
2. How are precision measurements of atomic mass conducted?
Precision measurements of atomic mass are conducted using mass spectrometry, which involves ionizing atoms and then separating them based on their mass-to-charge ratios.
3. What is the significance of precision measurements of atomic mass in chemistry?
Precision measurements of atomic mass are crucial in chemistry because they allow us to accurately determine the composition of chemical compounds, as well as understand the behavior of elements in chemical reactions.
4. How do precision measurements of atomic mass contribute to our understanding of the universe?
Precision measurements of atomic mass provide valuable data for scientists studying the origin and evolution of the universe. They help us understand the processes that formed and continue to shape our universe.
5. What are some challenges that scientists face when conducting precision measurements of atomic mass?
Some challenges include the difficulty in isolating individual atoms for measurement, the potential for interference from other elements, and the need for extremely sensitive equipment to detect small mass differences.
