MHB Predicates and Quanitifiers - Can't understand Question
  • Thread starter Thread starter Tvtakaveli
The discussion revolves around understanding a logical statement involving predicates and quantifiers concerning integers. The statement expresses that if m is odd and n is greater than 100, then the difference n - m should also be greater than 100. A participant clarifies that the implication can be interpreted as "If m is odd and n is big, then n - m is big." A counter-example provided involves choosing m = 9 and n = 105, resulting in n - m = 96, which is not greater than 100, thus proving the statement false. The conversation emphasizes the importance of correctly interpreting logical implications and validating them with examples.
Tvtakaveli
Hi I'm new here but can't get my head around this problem.
We use the predicates O and B, with domain the integers. O(n) is true if n is odd, and
B(n) is true if n if big, which here means that n > 100.
(a) Express ∀m, n ∈ Z|O(m) ∧ B(n) ⇒ B(n − m) in conversational English.
(b) Find a counter-example to this statement.
Now i take it two ways;
Just expressing the imply part of the statement so,
The difference between n and m is big.
Or is it deeper than that like;
For every m, n is an element of Z and so m is odd and n is big. This implies the difference between n and m is big.
Thank you for the help!
I assume that ∧ binds stronger than ⇒ (similar to times and plus, respectively). This is a usual convention. Then the formula should be read literally. The part after | has the form P ⇒ Q. Such formula is read "If P, then Q". Next, the assumption P is O(m) ∧ B(n). This is read "m is odd and n is big". Finally, the conclusion Q of the implication is B(n − m), which is read "n - m is big". Altogether the quantifier-free part is "If m is odd and n is big, then n - m is big". Adding the quantifiers gives the final answer:
For all m and n, if m is odd and n is big, then n - m is big.
I would say that if it is stipulated that the domain is the set of integers, it is not necessary to say "for all integer m and n": this is assumed.
Hi, thanks for clearing that up, I really appreciate it.
So just to confirm, producing a counter statement would just be substituting values. E. G.
Let m = 9 and n=105. 105-9 =96 which is not big (>100) therefore the statement is irrational.
Yes. The only remark is that statements can be true or false, and real numbers can be rational or irrational.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
