Predictions from loop quantum gravity
In summary, loop quantum gravity does not have any clear, definitive predictions at this time. Some approaches within LQG may predict violations of Lorentz invariance, but there is no consensus on this among researchers. Other potential tests, such as observations from the Fermi telescope, may help narrow down the possibilities and guide further research. However, the current focus of LQG is on finding a consistent theory and achieving a correct limit, rather than making specific predictions.
Micha
145
It is always said, that string theory makes no testable predictions.
At least there are some qualitative predictions like supersymmetry and extra dimensions.
One prediction of loop quantum gravity is a violation of Lorentz invariance.
Are there other predictions of loop quantum gravity?
I wouldn't count the quantization of space and area, because a direct test seems forever impossible.
It's a good question to be asking, Micha. As I think you know I am an observer on the sidelines---I can't speak for the researchers in the various nonstring QG (like Loop, like spinfoam, like causal triangulations...) I just do the best I can to report overview and trends.
Almost all the nonstring QG embodies 3 spatial dimensions. Several approaches would be badly refuted if experimentalists were to find extra spatial dimensions.
More specifically Causal Triangulations QG (Loll et al) predicts 4D spacetime at macro scale going continuously down to around 2D at micro scale. So dimensionality declines with scale. It would be badly refuted if evidence showed up of extra dimensions of the sort string theorists imagine.
So there is clearly falsifiability in as much as many presumed LHC experts have written about the possibility of LHC to find evidence of extra dimensions (I do not think it at all likely but they talk about it as a possibility.)
There is no LQG prediction as far as I know of breaking Lorentz invariance---it does not predict violation in the sense of the existence of a preferred frame. As you probably know there is a prediction in some versions of a modified Lorentz invariance in which both the speed c and an energy like the Planck energy appear the same to all observers. (sometimes called DSR for doubly special relativity.) There are different versions of DSR, and also an energy-dependent metric conjecture (the socalled rainbow metric).
Certain versions of LQG apparently differ as to what they predict in the way of energy-dependent metric, or energy-dependent speed of photons. I have seen predictions differing as to SIGN of the energy-dependent effect. The situation is confused. Anything along these lines will necessarily rule out SOME of the versions. At least it will narrow down the field.
The Fermi Gammaray Space Telescope (formerly called GLAST) has started to report data. It is sensitive enough to detect an energy-dependent advance or delay in arrival time of the expected size. Either way it goes will be helpful.
But there is no overall prediction about this derived from LQG as a whole. there is no one single modification of Lorentz invariance that all the approaches predict!
So one cannot say that testing for energy-dependent arrival times by the Fermi satellite will be a global test of LQG as a whole. It will just help them narrow down what to work on.
So Micha, I don't see very much in the way of unique hard predictions. Some ongoing observations, as by the gammaray telescopes, and conceivably LHC, will be helpful. But there is no blanket commitment to a falsifiable prediction. As far as I can see.
In his recent talk at Geneva, Rovelli stressed that the goal at present is to find at least one consistent theory--constructing a quantum field theory NOT on a pre-ordered space, and having the correct behavior in the limit. It is a hard job and they are still working on that--just find one theory that works. When there are two or more, then will be the time to test, so as to rule out one or the other. for them now, getting GR in the limit is the big test.
(that is how I measure the progress they have made in the past two years)
I must first clarify that both string theory and loop quantum gravity are still theoretical frameworks and have yet to be fully proven or tested. However, it is important to note that making testable predictions is a crucial aspect of any scientific theory.
While it is true that string theory has faced challenges in making direct testable predictions, it is not entirely accurate to say that it makes no testable predictions at all. As mentioned, there are qualitative predictions such as supersymmetry and extra dimensions that can potentially be tested through experiments at high energy colliders.
On the other hand, loop quantum gravity does make a specific and testable prediction: a violation of Lorentz invariance. This refers to the principle of relativity, where the laws of physics should be the same for all observers moving at a constant velocity. This prediction can potentially be tested through experiments involving high-energy particles and their interactions.
Aside from this, there are ongoing efforts to explore other testable predictions of loop quantum gravity. Some examples include the possibility of a discrete structure of space-time, the existence of quantum black holes, and the behavior of gravitational waves. While these predictions may not be directly testable at the moment, advancements in technology and experimental techniques may make it possible in the future.
In conclusion, while both string theory and loop quantum gravity have their own challenges in making testable predictions, it is important to continue exploring and testing these theories in order to advance our understanding of the fundamental laws of the universe.
Related to Predictions from loop quantum gravity
1. What is loop quantum gravity (LQG)?
Loop quantum gravity is a theoretical framework in physics that attempts to reconcile general relativity and quantum mechanics. It proposes that space and time are quantized at a very small scale, and that the universe is made up of tiny indivisible units of space and time called "loops".
2. How does LQG make predictions?
LQG makes predictions by using mathematical equations to describe the behavior of these tiny loops of space and time. These equations can then be used to calculate properties of the universe, such as the behavior of matter and energy on a very small scale.
3. What predictions has LQG made so far?
Some of the predictions made by LQG include the possibility of a minimum length scale in the universe, the existence of black hole remnants, and the potential for the universe to have a non-singular beginning. However, these predictions have not yet been confirmed by experiments and are still being studied.
4. Is LQG compatible with other theories of physics?
LQG is still a developing theory and is not yet fully compatible with other theories of physics, such as quantum field theory. However, efforts are being made to reconcile LQG with other theories, and some progress has been made in this area.
5. How can LQG be tested or proven?
Currently, there is no experimental evidence to support or refute LQG. However, scientists are working on ways to test LQG predictions, such as through observations of gravitational waves or the behavior of matter in extreme conditions. It is also possible that future advancements in technology may provide the means to test LQG predictions.
  • Beyond the Standard Models
11K
