Preliminary knowledge on tensor analysis
In summary, the conversation discusses the definition and properties of tensors, particularly in the context of tensor analysis and differential geometry. The conversation also touches on the distinction between the metric tensor and the Ricci tensor, and the importance of the metric tensor in defining inner products and distances on a manifold. The book recommendations for further understanding are "Introduction to Smooth Manifolds" by John M. Lee and "A Comprehensive Introduction to Differential Geometry, vol. 1" by Michael Spivak.
ChrisVer
464
I am not sure whether this needs to be transported in another topic (as academic guidance). I have some preliminary knowledge on tensor analysis, which helps me being more confident with indices notation etc... Also I'm accustomed to the definition of tensors, which tells us that a tensor is an object which has a given transformation law... Like a tensor of rank [itex](n,k)[/itex] transforms under a coordinate transformation (diffeomorphism) [itex]\phi^{a}(x^b)[/itex] as:
[itex] (T')^{a_{1}...a_{n}}_{b_{1}...b_{k}}= \frac{\partial \phi^{a_{1}}}{\partial x^{w_{1}}}...\frac{\partial \phi^{a_{n}}}{\partial x^{w_{n}}} \frac{\partial x^{r_{1}}}{\partial \phi^{b_{1}}}...\frac{\partial x^{r_{k}}}{\partial \phi^{b_{k}}} (T)^{w_{1}...w_{n}}_{r_{1}...r_{k}}[/itex]
However, a tensor is not only defined as such... I learned that a (n,k) tensor can also be a mapping... In particular it takes vectors from a vector space (n times) and its dual (k times) and maps them to the real numbers:
[itex]T: V \otimes V \otimes ... \otimes V \otimes V^{*}\otimes ... \otimes V^{*} \rightarrow R [/itex]
so in that case instead of indices one can use arguments of the corresponding vectors in V...
eg the metric is a tensor [itex]g: V \otimes V \rightarrow R[/itex] which gets translated to [itex]g_{ab}x^{a}x^{b}= g(x^{a},x^{b})= ds^{2}[/itex]
But wouldn't also the metric send me from [itex]V \rightarrow V^{*}[/itex] like an object which lowers or raises indices? In that case: [itex]g(x^{a})=x^{*b}[/itex]
Is there any good book that can give me a good insight on this way of defining things? Thanks...
Introduction to smooth manifolds by John M. Lee is great. I learned these things from A comprehensive introduction to differential geometry, vol. 1, by Michael Spivak, which is also good, at least about the definitions of tensors.
Regarding the metric...
We have ##g:V\times V\to\mathbb R##. Let ##g(\cdot, v)## denote the map ##u\mapsto g(u,v)## from V into ##\mathbb R##. This map is actually an element of V*. So the map ##v\mapsto g(\cdot,v)## is from V into V*.
The components of ##g(\cdot,v)## are the numbers ##g(e_i,v)=g(e_i,v^je_j)=v^jg(e_i,e_j)=g_{ij}v^j##.
Edit: Note that it's the components of the tensors that "transform" from one coordinate system to another. The tensors themselves are coordinate independent. This would be apparent even in the old-fashioned approach, if the books that use it had bothered to write the definition in a way that resembles actual mathematics.
Likes ManUp and ChrisVer
I would like to add that any rank (0,2) tensor can be regarded as either a map from ##V\times V\rightarrow \mathbb{R}## or as a map ##V\rightarrow V^*##. This is not restricted to the metric.
Thanks Fredrik..
Hmmm Matterwave, you are true I guess (by definition)... but what distinguishes for example the Ricci Tensor to the metric with such a definition? The vector spaces? (I know that both are tensors so they must satisfy this condition, but the way they act on/map these spaces must be different?)
ChrisVer said:
Thanks Fredrik..
They are different tensors, so the maps are different (and may be very different!) of course. The special thing about the metric is that it defines the inner product on your manifold, turning your manifold into a Reimmanian manifold. This allows you to start talking about things like distances (indeed, this is perhaps the aspect of the metric tensor) between two points.
So, let's look at the map that ##g## induces on your manifold. If I put a vector in it, I get out a one form from the map: ##\tilde{V}(\quad)\equiv g(V,\quad)##. Now, what is the inner product of this vector with itself? Well it's simply: ##V\cdot V=g(V,V)=\tilde{V}(V)##. This means that the contraction of ##\tilde{V}## with ##V## is equal to the inner product of ##V## with itself. Similarly, the contraction of anyone form ##\tilde{W}## with any vector ##V## is equal to the inner product between the vector ##V## and the vector ##W## which was mapped into ##\tilde{W}## by our metric tensor.
This is a very natural thing. It's a very natural definition to define the "one form dual to the vector V" as: ##\tilde{V}(\quad)\equiv g(V,\quad)##.
It is NOT natural to define "the one form dual to the vector V" as, for example, the one form to which the Ricci tensor maps V. In other words, I would not like to say: ##\tilde{V}=R(V,\quad)##. Why is this? Well the Ricci tensor doesn't define inner products on our vector space, the metric tensor does. So if we made the above definition, then the inner product of V with itself is no longer the contraction of V with its dual! (i.e. ##\tilde{V}(V)=R(V,V)\neq V\cdot V=g(V,V)##). This is very unnatural. And in fact, since the Ricci tensor might be 0 on our manifold, which would be the case if our manifold is Ricci flat (e.g. a vacuum solution to the Einstein field equations), then we might not get a unique mapping in that case, since if ##R(V,W)=0## for all ##V,W##, then it maps all vectors ##V## into the 0 one-form (an infinite to 1 mapping!).
So what's special about the metric, that let's us call it the metric, rather than any rank (0,2) tensor? Well, it must satisfy some very important properties, namely:
1. It must be symmetric: ##g(V,W)=g(W,V)\quad \forall V,W##
2. It is non-degenerate, that means if ##V\neq0## then there exists a ##W## such that: ##g(V,W)\neq 0##
3. It must be positive definite everywhere (necessary if we want to call our manifolds Riemannian): ##g(V,W)>0,\quad V\neq 0\quad and\quad W\neq 0##
Property 3 may be relaxed, and a non-positive definite metric is called "pseudo-Riemannian", the most important example of such is a Lorentzian manifold (the manifolds of General relativity).
Hopefully this helps!
Likes 1 person
To say part of it in other words, any non-degenerate form on a vector space gives rise to a canonical isomorphism ( i.e. an isomorphism independent of the choice of basis) between a finite-dimensional vector space and its dual ( note that a f.d vector space and its dual are _always_ isomorphic, by dimension reasons.)
Like you said, a tensor is a multilinear map, i.e., a map that is linear in each argument separately, and the inputs of this tensor/map are both elements of the vector space often called the covariant part ) and elements of its dual (often called covariant ); you may also have purely covariant -- as in the case of a metric-- or purely contravariant tensors/maps.
Related to Preliminary knowledge on tensor analysis
1. What is tensor analysis?
Tensor analysis is a branch of mathematics and physics that deals with the study of tensors, which are mathematical objects that describe the linear relationships between vectors, scalars, and other tensors. It is commonly used in fields such as mechanics, electromagnetism, and general relativity.
2. What are the applications of tensor analysis?
Tensor analysis has various applications in physics, engineering, and computer science. It is used to describe the stress and strain in solid materials, analyze fluid mechanics and fluid dynamics, and model the behavior of electromagnetic fields. It is also used in image and signal processing, machine learning, and data analysis.
3. What are the different types of tensors?
There are several types of tensors, including scalars, vectors, matrices, and higher-order tensors. Scalars are single numbers, vectors have both magnitude and direction, and matrices are arrays of numbers. Higher-order tensors, also known as multidimensional tensors, have more than two indices and can represent more complex relationships between quantities.
4. How is tensor analysis related to linear algebra?
Tensor analysis is closely related to linear algebra, as tensors can be represented as multi-dimensional arrays of numbers. Many of the concepts and operations in linear algebra, such as matrix multiplication, transpose, and determinant, also apply to tensors. However, tensor analysis introduces additional concepts and operations, such as tensor contraction and covariant differentiation, to deal with more complex mathematical objects.
5. Can tensor analysis be applied to non-Euclidean spaces?
Yes, tensor analysis can be applied to non-Euclidean spaces, such as curved spaces in general relativity. In these cases, the mathematical properties of tensors, such as their covariant transformation rules, must be modified to account for the curvature of space. This is where the concept of a covariant derivative, which takes into account the curvature of the space, becomes important in tensor analysis.
  • Linear and Abstract Algebra
