Preliminary Test of Alternating Geometric Series
In summary, a preliminary test of alternating geometric series is a method used to quickly determine the convergence or divergence of an alternating geometric series. It involves checking if the absolute value of terms in the series decreases as the index increases. However, this test is not always accurate and other convergence tests should be used to confirm the result. The alternating condition in the test is important as it ensures the series does not have a constant sign, which is necessary for the test to work properly.
The-Mad-Lisper
[tex]\lim_{n \to \infty}\frac{(-1)^{n+1} \cdot n^2}{n^2+1}[/tex]
[tex]\lim_{n \to \infty}a_n \neq 0 \rightarrow S \ is \ divergent[/tex]
I tried L'Hopital's rule, but I could not figure out how to find the limit of that pesky [itex](-1)^{n+1}[/itex].
Edit: This is not actually a geometric series, disregard that part of the title.
Is there a question somewhere here? You seem to have arrived at the correct conclusion for the correct reason, so what are you unsure about?
Computing the derivative of an exponential function results in another exponential function, which doesn't really help when it comes to using L'Hopitals rule.
This is a rule for series. Why is this relevant? There are no series in your post.
Your post is very confusing! You title this "alternating geometric series" but appear to be asking about a "sequence" rather than a "series". Further this is not a "geometric" series or sequence. If the "problem statement" is to determine whether or not the series [itex]\sum_{n=0}^\infty \frac{(-1)^n n^2}{n^2+ 1}[/itex] converges then you should know that an alternating series, [itex]\sum_{n=0}^\infty a_n[/itex], converges if and only if the sequence [itex]a_n[/itex] converges to 0. Finally, you ask about the limit of [itex](-1)^n[/itex]. That sequence does not converge so has no limit but that is irrelevant to this problem.
Likes The-Mad-Lisper
try dividing the denominator and the numerator by n^2. you'll be left out with ones and one/infinities which go to zero then you're left with a simple equation.
An alternating series is of the form ##\sum_n (-1)^na_n##. The limit in your test concerns ##a_n##, not ##(-1)^na_n##.
The question in the first post has been answered, and the OP hasn't been back for a couple of years, so I'm closing this thread.
Related to Preliminary Test of Alternating Geometric Series
1. What is a preliminary test of alternating geometric series?
A preliminary test of alternating geometric series is a method used to determine whether an alternating geometric series converges or diverges. It is a quick and simple test that can be used before applying more complex methods of convergence testing.
2. How do you perform a preliminary test of alternating geometric series?
To perform a preliminary test of alternating geometric series, you must first check if the absolute value of the terms in the series decreases as the index increases. If this condition is met, then the series passes the test and it can be concluded that the series converges. If the terms do not decrease in absolute value, then the series fails the test and it is inconclusive whether it converges or diverges.
3. Can a series pass the preliminary test but still diverge?
Yes, it is possible for a series to pass the preliminary test of alternating geometric series and still diverge. This is because the test only checks for a specific condition and does not take into account other factors that may affect the convergence or divergence of a series.
4. What is the significance of the alternating condition in the preliminary test?
The alternating condition in the preliminary test is important because it ensures that the series does not have a constant sign. This is necessary for the test to work, as it relies on the alternating signs of the terms to determine convergence or divergence.
5. Is the preliminary test of alternating geometric series always accurate?
No, the preliminary test of alternating geometric series is not always accurate. There are cases where a series may pass the test but still diverge or fail the test but still converge. It is important to use other convergence tests to confirm the result of the preliminary test.
