shauntur
- 3
Hi there,
I have set up a flow loop for a uni experiment that will teach other students about the bernoulli equation. The loop will use a few working section that will increase and decrease pressure due to diameter, velocity and height changes.
I first set-up my loop with the pump at the end, pulling the water through the system so that i wouldn't have to worry about any discharge pressures. However i had to reverse this to get the pressure readings in the range of the pressure transducers.
I have been calculating the pressures at a point using:
I am able to calculate the flow rate, as the difference p2-p1 will cancel the constant out. If i use the pump curve to find the pressure head at this flow rate, is this the discharge pressure that i can add to the equation above to obtain the actual pressure at each point.
Any help would be appreciated,
Thanks
Shaun
p = density*gravity*height - 0.5*density*(velocity^2)
where height is the distance below the water level to the transducer.
I want to be able match the recorded pressures with some calculations, But now i have the pump at the start i am unsure how this adds to the pressures?where height is the distance below the water level to the transducer.
Thanks
Shaun
