Pressure at same height in same fluid?
In summary, the conversation discusses the pressure differences at points A and B in a sealed tank with a partition. It is noted that pressure at the same height in the same fluid is usually equal, but in this case, it is not due to the tank being sealed. The conversation also touches on the effect of air pressure on the water level and the importance of equalizing pressure at the bottom of the tank. It is mentioned that this must occur in order for the fluid to be in equilibrium.
Kqwert
160
A sealed has a partition stuck down in water, creating two separate air pockets. The pressure at A is measured to 95 kPa (absolute) and the temperature is 20 C. Find the pressure at B.
Why is the pressure at A not equal to B? Doing U-tube exercises one uses that the pressure at the same height in the same fluid is equal, which is not the case here. Is it because the tank is sealed?
If I'm not mistaken:
Yes, it's because the tank is sealed. The water is at different heights so the pressure differential is given by:
$$\rho_A g h_1 - \rho_w g h_2 - \rho_B g h_3 \\ = g(2\rho_A - 2\rho_w) \\ = 2g(\rho_A-\rho_w)$$
assuming ##\rho_A = \rho_B##
its been a while since I've done fluids so i may indeed be mistaken, take it with a grain of salt :)
Yes.
When we think about the pressure under water we sometimes ignore the effect of the air above because it's roughly the same everywhere but that's not always valid. Changes in the air pressure above the water changes the pressure below the water. This can cause the sea to rise and fall in different places (an example is a storm surge).
Consider the pressure at the bottom of the tank. It must be the same pressure on the left as the right or fluid would flow horizontally. However the depth of water on the right is greater than that on the left by 2m. So something must be equalising the pressure at the bottom OK?
Imagine if the tank was open at the top. The water on the right would fall until it was equal both sides. So something else must be preventing this and equalising the pressure at the bottom. One way to think of it is that the water has already fallen a bit on the right and risen on the left. This increased air pressure on the left and reduced pressure on the right is what causes the pressure at the bottom to be equal.
Thanks! is it possible to prove that the pressure at the bottom of the tank HAVE to equal each other?
The fluid is static. ie. in equilibrium. Remember that you can think of pressure at a point as being exerted equally onto that point from all directions. So if the pressures were different at the bottom on the left and right, then there would be a net flow from high pressure to low pressure ie not static
Likes CWatters
Related to Pressure at same height in same fluid?
1. What is the definition of pressure?
Pressure is defined as the amount of force exerted per unit area.
2. How is pressure at the same height in the same fluid affected by the density of the fluid?
The pressure at the same height in the same fluid is directly proportional to the density of the fluid. This means that as the density increases, the pressure also increases.
3. Why does pressure increase with depth in a fluid?
This is due to the weight of the fluid above pushing down on the fluid below. As depth increases, the weight of the fluid increases, resulting in an increase in pressure.
4. How does the shape of a container affect pressure at the same height in the same fluid?
The shape of a container does not affect the pressure at the same height in the same fluid as long as the height and density of the fluid remain the same. Pressure is only dependent on the height and density of the fluid, not the shape of the container.
5. What is the relationship between pressure and fluid velocity at the same height in the same fluid?
At the same height in the same fluid, pressure and fluid velocity have an inverse relationship. This means that as velocity increases, pressure decreases and vice versa. This is known as Bernoulli's principle.
  • Classical Physics
