Pressure at surface and bottom of pool
In summary: That is compression.When the liquid is less dense, the buoyant force is weaker. It might not be enough to balance the gravitational force on the cube. In that case the rod must pull up on the cube. That is tension.In summary, the conversation discusses the pressure and force ratios between two pools, A and B, with equal depth but different surface areas. The ratios of pressure at the top and bottom surfaces of the pools are found to be equal, regardless of the difference in surface area. The conversation also touches on the concept of buoyancy and the effects of density on the forces acting on an object immersed in a liquid. The rod connecting the cube to the bottom of the liquid container may experience compression or
Taniaz
364
Two pools A and B have exactly the same depth, but A has 10 times the surface area, both at the top and at the bottom. Find the ratio of the total pressure (a) at the top surface of A to that at the top surface of B
(b)at the bottom of A to that at the bottom of B.
P=F/a or P=pgh
For a, since they're at the surface they both have a pressure = atmospheric pressure so the ratio is 1?
For b, since they're at the same depth, they have the same pressure because even if the area of A is 10 times the area of B, that means there's a force of about 10 times as big acting on the area as well so the pressure is the same. Is my reasoning correct? I don't see how the area affects part a? I mean the force and area at the surface for both will change in a way that their pressure will equal the atmospheric pressure. Do I need to consider atmospheric pressure in b as well? Even then, the ratio would be 1?
You are correct. Surface area has nothing to do with pressure. (If they asked for total force, not pressure, then area would count for something.)
Thank you!
Just one more thing. We have a cube immersed fully in a liquid where the density of the liquid is p1 and the density of the cube is po. The cube is linked to the bottom of the container of the liquid by a rod. If p1 > po then the body would want to float so the net force would be upwards hence the rod would be under tension. If p1 < po then the body would want to sink so the net force would be downwards hence the rod will be under compression. If p1=po then it's neutrally stable, so it will move wherever, hence the rod will be under compression or will it be under nothing? Am I right with these 3?
Assuming the rod is thin enough, then you are correct. When p1 = po, the buoyant force cancels the object's weight, so it doesn't add any tension to the rod.
Yes that makes sense, so it won't be under any compression or tension? Thank you!
I was just worried about this one:
That is correct too.
Thank you Doc Al and Haruspex for your help :)
Hi again!
This particular question that I asked a few months ago (in reply number 3):
"We have a cube immersed fully in a liquid where the density of the liquid is p1 and the density of the cube is po. The cube is linked to the bottom of the container of the liquid by a rod. If p1 > po then the body would want to float so the net force would be upwards hence the rod would be under tension. If p1 < po then the body would want to sink so the net force would be downwards hence the rod will be under compression."
Wouldn't the rod be under compression if the body wanted to float since the rod is trying to keep the body down?
And wouldn't it be under tension if the body wanted to sink?
Just the opposite. If the body wanted to float it would be stretching the rod; if it wanted to sink, it would be compressing the rod.
How will it be stretching the rod?
When the cube pulls up on the rod, it stretches the rod creating tension. (You could replace the rod with a rope.)
I can't seem to get my head around this, wouldn't the rod be pulling the rod when it would want to sink and pushing against the rod when it would want to float?
The rod is what is keeping the cube to the bottom of the liquid so it would push on the rod when it would want to float? :frown:
Forget about the fluid for a minute. Remove the liquid. You have a cube sitting on top of a rod. Is the rod compressed or stretched?
Likes cnh1995
Maybe you are confusing yourself by thinking in terms of what the cube "wants".
What the cube does is a consequence of the forces acting on it. If it does not move then those forces must be in balance.
The pressure in the liquid is greater at greater depths, so it pushes more strongly on the underside of the cube than on top. That is what creates the buoyant force. When the liquid is dense the buoyant force is strong. If it exceeds the gravitational force on the cube then to balance the buoyant force the rod must pull down on the cube.
Likes cnh1995
FAQ: Pressure at surface and bottom of pool
What is the definition of pressure at the surface and bottom of a pool?
The pressure at the surface and bottom of a pool refers to the force exerted by the weight of the water in the pool on a unit area of the surface or bottom. It is typically measured in units of force per unit area, such as pounds per square inch (psi) or pascals (Pa).
How does the pressure at the surface and bottom of a pool change with depth?
The pressure at the surface and bottom of a pool increases with depth. This is because the weight of the water above a certain depth increases as you go deeper, resulting in a greater force exerted on the surface or bottom at that depth.
What factors affect the pressure at the surface and bottom of a pool?
The pressure at the surface and bottom of a pool is affected by the depth of the water, the density of the water, and the acceleration due to gravity. It is also affected by any objects or people in the pool that may displace water and change the pressure distribution.
How does the pressure at the surface and bottom of a pool relate to swimming depth and buoyancy?
The pressure at the surface and bottom of a pool plays a key role in swimming depth and buoyancy. As a person swims deeper in the pool, the pressure increases, making it more difficult to move and stay afloat. Buoyancy is also affected by the pressure, as objects or people with a greater density than water will sink to the bottom due to the higher pressure at the bottom.
Why is it important to understand the pressure at the surface and bottom of a pool?
Understanding the pressure at the surface and bottom of a pool is important for safety reasons. It helps swimmers and pool maintenance personnel understand the forces at play in the pool and take appropriate precautions. It is also important for engineers and designers when constructing pools to ensure they can withstand the pressure and avoid potential structural failures.
