Pressure at the center of an accelerating sphere
In summary, the problem of finding the pressure at the center of a glass sphere filled with water and a small air bubble while accelerating to the right can be solved using either Pascal's law or by considering forces and pressure differences. Both approaches result in the equation P = ρh√(a2+g2), where P is the absolute pressure at the center, ρ is the density of water, h is the height of the sphere, and a and g are the acceleration and gravitational constant, respectively.
Nathan B
Consider a glass sphere completely filled with water except for a small air bubble at 1 atmosphere. The sphere is accelerating to the right. What is the pressure at the center of the sphere?
Let Pe = Atmospheric pressure
r = radius of sphere
pw = density of water
a = acceleration of sphere
I've previously solved this problem successfully with Pascal's law P = Pe + pw*g*h
A successful solution was found with the equation P (center of sphere) = Pe + pw * sqrt (g^2 + a^2) r
While this solution rendered the correct answer, my professor told me that summing the acceleration with gravity is not a conceptually correct way of solving this problem, and that it should be solved with forces and pressure differences. Could someone please show me how that might be done?
The equation that you need is the force per unit volume equals minus the pressure gradient: ## \vec{f}_v=-\nabla P ## . You also know (basically F=ma) that ## \vec{f}_v=\delta \,\vec{a}= \delta \, a \, \hat{x} ## where ## \delta ## is the density (kg/m^3) etc. With the small air bubble at 1 atm., I think that puts boundary conditions on the internal pressure at the rightmost glass surface. One other item to consider would be gravity. The gravity equations require that ## -\nabla P -\delta g \hat{z}=0 ##. (static equilibrium from the gravity. The pressure gradient force plus the gravity force per unit volume must add to zero). Perhaps the gravity could be ignored for at least the first calculation of the pressure from the acceleration. Otherwise, you have ## -\nabla P=\delta \, a \, \hat{x}+\delta \, g \, \hat{z} ##. For the gradient operator in the first equation without the gravity, you only need the ## \frac{\partial{P}}{\partial{x}} ## term. ## \\ ## Editing: @Nathan B Your approach in the OP to introduce gravity as well I think simplifies the solution: There is a symmetry in this differential equation if you let ## \vec{u}=\delta \, a \, \hat{x} +\delta \, g \, \hat{z} ## and consider the gradient along the ## \vec{u} ## direction, and integrate ## dP ## back to the center along this line. In fact, doing this gives the exact same answer that you gave in the OP.
After working at it for a bit I came up with this solution with forces. Still not with pressure gradients, but it works.
ΣFy = 0
ΣFx = ma
As the buoyant force supplies all force in the x direction, FBx = ma
FB = ma/cos θ = ma/(ma/√((ma)2+FG2)) = √((ma)2+(mg)2) = m√(a2+g2)
Let P = gauge pressure and A = Area
P = m√(a2+g2)/A
m/A = ρh
P = ρh√(a2+g2)
Let Pa = absolute pressure and Po = atmospheric pressure
Pa = Po + ρh√(a2+g2)
Which is the same answer I got originally, just achieved in a somewhat more rigorous manner.
It looks good what you even did in the first posting. To do it with gradients, you get ## dP/dr=-\delta \, \sqrt{a^2+g^2} ## where ## r ## is in the ## \vec{u} ## direction, and I'm no longer writing it as a partial derivative. (The ## r ## is now basically the height in the ## \vec{u} ## direction with ## \vec{u}=\delta \, a \, \hat{x}+\delta \, g \, \hat{z} ##). Integrating: ## P(0)=P(R)+\int\limits_{0}^{R} (\frac{dP}{dr}) \, dr=P(R)+\delta \, \sqrt{a^2+g^2} \, R ## which is the same result that you got. In doing these buoyancy problems, it can be helpful to use the pressure gradient form. ## \\ ## Editing: Meanwhile your approach of treating the presence of a gravitational field as equivalent to an upward acceleration of ## g ## is completely accurate and should be seen as a valid solution. Alternatively, an acceleration of ## a ## to the right could be seen as equivalent to a gravitational field with that magnitude pulling to the left. Editing: The only other thing I can think of that he may be looking for is a derivation of the form: ## [P(x)-P(x+\Delta x)]A=\delta \, \Delta x \, A \, a ## which gives ## -\frac{dP}{dx}=\delta \, a ##, which is a simplified form of ## -\nabla P=\delta \, \vec{a} ##.
Related to Pressure at the center of an accelerating sphere
What is the formula for calculating the pressure at the center of an accelerating sphere?
The formula for calculating the pressure at the center of an accelerating sphere is P = ρaR, where P is the pressure, ρ is the density of the sphere, a is the acceleration, and R is the radius of the sphere.
How does the pressure at the center of an accelerating sphere vary with the acceleration?
The pressure at the center of an accelerating sphere is directly proportional to the acceleration. This means that as the acceleration increases, the pressure at the center also increases.
Does the density of the sphere affect the pressure at the center?
Yes, the density of the sphere does affect the pressure at the center. A higher density sphere will result in a higher pressure at the center, while a lower density sphere will result in a lower pressure at the center.
How does the radius of the sphere impact the pressure at the center?
The radius of the sphere also affects the pressure at the center. As the radius increases, the pressure at the center decreases, and vice versa.
Can the pressure at the center of an accelerating sphere ever be zero?
No, the pressure at the center of an accelerating sphere can never be zero. This is because the acceleration and density of the sphere will always result in a non-zero pressure at the center.
