DocZaius
- 365
- 11
Please note that I am making this problem up and it is not "assigned" to me:
A large tank of water has two small holes at the same height, near the bottom. Hole A's area is twice hole B's area. Is the volumetric flow rate (volume per time) of water out of hole A bigger than B? If so, by how much?
* The height (and width) of the tank is much greater than the radii of the holes.
* You may ignore the pressure difference between the top and bottom of each hole.
I am not sure! Hagen-Poiseuille seems to be about volumetric flow along a pipe with a pressure difference across it. This problem does not seem like it could be approximated as such.
Hagen-Poiseuille equation:
[itex]\Delta P = \frac{8 \mu L Q}{\pi r^{4}}[/itex]
Bernoulli's principle seems more appropriate, but it seems to imply that the velocity is constant between each hole and that twice the area might mean twice the flow? Unsure about this, but it feels too simple.
Bernoulli's principle:
[itex]\frac{v^{2}}{2} + g z +\frac{p}{\rho} = constant[/itex]
See above. A most likely wrong application of Bernoulli's principle might mean that the velocity of water out each hole is equal and that there is thus twice as much flow out a hole twice the size. The reason this doesn't feel right is that, from experience, a smaller hole seems to lead to a higher velocity. Is the higher velocity enough to make up the reduction in area? I don't know. I don't think so, but I'd like to know.
edit: As a side note, this would be an interesting experiment to do. Fill a large tank of water and create a hole at the bottom. The hard part is making a hole whose area can be accurately measured. Measure the amount of water that comes out of the hole over some time. Then increase the size of the hole and repeat. With enough data points, plot them all with flow rate on the y-axis and area on the x axis. Then fit a y = C1*(x^C2) curve to it to find a scaling factor and power dependence.
