Senju Panicker
- 3
Hello all,
I am an Electronics Engineer, working in an R&D Organisation specializing in Electronics and Advanced Computing. My area of work is Control & Instrumentation related to Industrial Automation.
I am trying to identify the a solenoid valve to be used on a 2" pipe. For this I need to know the pressure in the pipe.
Water flowing in a pipe of 2" diameter is branching into 4 pipes having 1" diameter. At the output of the 4 pipes there is a sprinkler, which works at a pressure of 120 psi. The main pipe is connected to a pump having 10 HP motor. i.e. Water pumped from a 10 HP Pump flows through a 2" diameter pipe and branches into 4 pipes of 1" diameter before flowing out through sprinklers.
I would like to know the pressure in the 2" Main Pipe.
Thanks in advance.
Regards
Senju Panicker
Thanks in advance.
Regards
Senju Panicker
