Pressure in canonical ensemble
In summary: KmBGlxUXLVY&qid=ZDYHAXxsNQ&oe=UTF-8In summary, pressure in a closed system is the average force of particles hitting against the wall of said system. The obvious way to manipulate pressure in a closed system is to either shrink
SchroedingersLion
215
57
Greetings,
I am having a hard time in understanding intuitively how pressure does not automatically stay constant in a canonical ensemble (=NVT ensemble).
Pressure in a closed system is the average force of particles hitting against the wall of said system. The obvious way to manipulate pressure in a closed system is to either shrink the volume so the particles would have less space and collide with the boundary more often, or to increase the temperature so the average momentum of the particles would increase and thus the force they hit the boundary with.
But both V and T stay constant in the canonical ensemble.
So how come pressure fluctuates?
Regards
SL
A canonical ensemble represents the possible states of a thermodynamic system which is characterized by a fixed number of particles and a fixed volume and which is allowed to exchange heat with a huge heat bath at a "fixed" temperature T. Hence, the energy of such a system can fluctuate when considering its behaviour in course of time.
As you stated, the pressure is an average quantity. The forces with which the particles hit the walls are, at the microscopic level, wildly fluctuating quantities. What you control from outside is the volume, and if the volume and the temperature are held constant, then the average pressure is a constant. There are always fluctuations about the average value, along with the energy, as pointed out by Lord Jestocost above.
Thanks guys.
I was under impression that the three 'constant' quantities, like N,V,T in the canonical ensemble or N,V,E in the microcanonical ensemble can also fluctuate around a constant average (N and V can even be constant all time). For example, when learning about how to simulate a thermostat in a molecular dynamics simulation, it was said that even in a canonical ensemble, T can fluctuate and only the average stays constant.
If it is the same with p, then one could call the N,V,T ensemble also a N,V,T,p ensemble, right?
How would one define a canonical ensemble with changing temperature? What are the conditions?
FAQ: Pressure in canonical ensemble
1. What is pressure in a canonical ensemble?
Pressure in a canonical ensemble is a thermodynamic variable that measures the force exerted on the walls of a container by the gas particles inside. It is a measure of the average force per unit area that the gas exerts on the container.
2. How is pressure related to temperature in a canonical ensemble?
In a canonical ensemble, pressure is directly proportional to temperature. This means that as temperature increases, pressure also increases, and vice versa. This relationship is described by the ideal gas law, which states that pressure is equal to the product of the gas's temperature and density.
3. What is the role of pressure in phase transitions in a canonical ensemble?
Pressure plays a crucial role in phase transitions in a canonical ensemble. It determines the conditions under which a substance will undergo a phase transition, such as melting or boiling. For example, at a certain pressure and temperature, a substance will transition from a liquid to a gas, and this pressure is known as the vapor pressure.
4. How is pressure calculated in a canonical ensemble?
Pressure in a canonical ensemble can be calculated using the ideal gas law, which states that pressure is equal to the product of the gas's temperature and density. Additionally, pressure can also be calculated using the virial expansion, which takes into account the interactions between gas particles.
5. What are the units of pressure in a canonical ensemble?
The standard unit of pressure in a canonical ensemble is Pascal, which is equal to one Newton per square meter. However, other common units of pressure include atmospheres, bars, and torr. The choice of unit depends on the specific application and context.
