Pressure inside a heated sealed vessel
In summary, pressure inside a heated sealed vessel is the force exerted by a gas or liquid on the walls of the vessel due to collisions of molecules. It is directly proportional to temperature and can be affected by factors such as volume, amount, type, and strength of the vessel walls. The pressure can be measured using a pressure gauge or manometer. If the pressure becomes too high, it can lead to vessel rupture or explosion, causing potential harm and hazards.
ouertani rachid
Please can you help me de find out the calculation steps leading to the partial pressure inside a heated closed vessel with 25 ml total capacity but filled 20mL with aquous mixture of 2 acids(HNO3/HF ;1/3)..I think to simplify the problem we could at a fisrt approximation assume that the mixture is water.. Experimentally we fixed the temperature to T1=80 ; 100 then 120°C.
Chemistry news on Phys.org
To a good approximation, the partial pressure from water will be given by the vapour/liquid boundary in the phase diagram, add the atmospheric pressure from air if you start the experiment with air inside.
Related to Pressure inside a heated sealed vessel
1. What is pressure inside a heated sealed vessel?
The pressure inside a heated sealed vessel refers to the force exerted by the gas or liquid contained within the vessel on its walls. This pressure is due to the collisions of the gas or liquid molecules with the walls of the vessel.
2. How does the pressure inside a heated sealed vessel change with temperature?
According to the ideal gas law, the pressure of a gas inside a sealed vessel is directly proportional to its temperature. This means that as the temperature increases, the pressure inside the vessel also increases.
3. What factors can affect the pressure inside a heated sealed vessel?
The pressure inside a heated sealed vessel can be affected by the temperature, volume, and amount of gas or liquid present inside the vessel. Additionally, the type of gas or liquid and the strength of the vessel walls can also impact the pressure.
4. How can the pressure inside a heated sealed vessel be measured?
The pressure inside a heated sealed vessel can be measured using a pressure gauge or a manometer. These instruments measure the force exerted by the gas or liquid on a small area and convert it into a pressure value.
5. What happens if the pressure inside a heated sealed vessel becomes too high?
If the pressure inside a heated sealed vessel becomes too high, the vessel may rupture or explode, releasing the gas or liquid contained within. This can also cause damage to the surrounding area and pose a safety hazard.
  • Mechanical Engineering
  • Mechanics
