Pressure of a fluid contained in a steel container
In summary, the steel container will expand to a final volume of {V_c} = {V_0}(1 + {\beta _{(steel)}}\Delta T) and the gas will expand to a final volume of {V_c} = {V_0}(1 + {\beta _{(gasoline)}}\Delta T). The pressure increase required to compress the gasoline back into the container is 1.756 \times {10^7}Pa.
squelch
A steel container is completely filled with gasoline, and then sealed. The temperature is then increased 11 degrees C. If the bulk modulus of gasoline is [itex]1.90 \times {10^9}Pa[/itex], find the increase in pressure of the gasoline if:
(a) The expansion of the container is considered.
(b) The expansion of the container is ignored.
(For gasoline, [itex]\beta = 9.60 \times {10^{ - 4}}^ \circ {C^{ - 1}}[/itex])
[tex]\Delta V = {V_0}\beta \Delta T[/tex]
[tex]p = \frac{F}{A} = - Y\alpha \Delta T[/tex]
The volume of the steel container will expand to a final volume:
[tex]{V_c} = {V_0}(1 + {\beta _{(steel)}}\Delta T)[/tex]
Similarly, the volume of the gas expands:
[tex]{V_c} = {V_0}(1 + {\beta _{(gasoline)}}\Delta T)[/tex]
Because we filled the container up to the brim before sealing it, we can assume the initial volumes are equal and that the initial pressure is one atmosphere (how relevant the latter point is I'm not sure). The initial volume isn't given, but I can relate the two ratios:
[tex]\frac{{\Delta {V_s}}}{{{\beta _s}}} = \frac{{\Delta {V_g}}}{{{\beta _g}}}[/tex]
Presumably, the liquid gasoline expands more than the steel canister. I know that pressure = force / area and I know that [itex]p = \frac{F}{A} = - Y\alpha \Delta T[/itex], but I'm not entirely sure how to apply that latter equation to what I know.
The easiest approach is to treat this as a two-step process. For the case where the container expansion is ignored, first calculate the new volume of the gasoline as if it were completely free to expand (thermal expansion). Then calculate the pressure increase that would be required to squeeze the gasoline back into the container (bulk modulus).
Chet
I think my *biggest* problem is that I can't seem to find an expression for the pressure increase required to compress the gasoline back into the container. Obviously this isn't an ideal gas, so I can't use the Ideal Gas Law. I'm not really sure at all what the [itex]-Y\alpha \Delta T[/itex] is trying to say. I just found an expression for the bulk modulus:
[tex]B = \frac{{\Delta P}}{{\frac{{\Delta V}}{V}}} = \frac{{\Delta P \cdot V}}{{\Delta V}}[/tex]
...and I'm trying to proceed from there.
I don't know what the Y in your equation stands for, but I'm guessing it is related to the ratio of the coefficient of thermal expansion to the bulk modulus. As far as your approach that you are trying to proceed with, this is the correct way to go.
Chet
So I found a procedure and tried to implement it this way:
[tex]\begin{array}{l}
\Delta {V_{(container)}} = \Delta {V_{(therm.expan.)}} - \Delta {V_{(stress)}}\\ ⇒
{V_0}{\beta _{(steel)}}\Delta T = {V_0}{\beta _{gasoline}} - \frac{{\Delta P \cdot {V_0}}}{{{B_{gasoline}}}}\\ ⇒
({\beta _{gasoline}} - {\beta _{steel}})\Delta T{B_{gasoline}} = \Delta P
\end{array}[/tex]
Plugging in the known constants, and taking the bulk modulus of steel to be [itex]3.6 \times {10^{ - 5}}^o{C^{ - 1}}[/itex] I get an answer of [itex]1.756 \times {10^7}Pa[/itex] for the first portion. Does this seem sensible?
Likes Delta2
\end{array}[/tex]
Thats what i also had in mind. b) is the same procedure, with just taking ##\Delta V_{container}=0##
Yup, that's the process I'm applying to the latter half. Thanks for the validation.
As a last point, I'm actually finding [itex]\Delta P[/itex], so is it accurate to say I need to add 1 ATM to the pressure?
edit: Upon rereading the question it's clear that this is the pressure reading they want, but I suppose it's worth knowing that the absolute pressure is [itex]\Delta P + 1 atm[/itex]
Related to Pressure of a fluid contained in a steel container
1. What is the formula for calculating the pressure of a fluid inside a steel container?
The formula for calculating the pressure of a fluid inside a steel container is P = F/A, where P is the pressure, F is the force applied to the container, and A is the area of the container where the force is applied.
2. How does the depth of the fluid affect the pressure inside a steel container?
The depth of the fluid does not have a direct effect on the pressure inside a steel container. However, the weight of the fluid does affect the force applied to the container and thus can impact the pressure.
3. Can the temperature of the fluid change the pressure inside a steel container?
Yes, the temperature of the fluid can affect the pressure inside a steel container. As the temperature of the fluid increases, the molecules move faster and exert more force on the container walls, resulting in an increase in pressure.
4. What factors can cause the pressure inside a steel container to increase?
The pressure inside a steel container can increase due to factors such as an increase in temperature, an increase in the amount of fluid in the container, or a decrease in the container's volume. Additionally, any external force applied to the container can also increase the pressure.
5. How can the pressure inside a steel container be measured?
The pressure inside a steel container can be measured using a pressure gauge or a manometer. These instruments measure the amount of force exerted on a particular area of the container's walls and convert it into a pressure reading.
20K
9K
