Pressure on block immersed in water?
In summary, the conversation discussed a problem involving Archimedes' principle and determining pressure. The pressure on the top of the block was found to be 500 pascals using the formula "pgh," but there was confusion about how to determine the pressure on the lower surface. It was explained that pressure is caused by the weight of the material above and is always directed inwards, normal to the surface of the object. The conversation also discussed a previous problem where the height of the water column was considered to be the height of the block plus the water under it.
khurram usman
87
i was solving a problem based on archimedes principle. but got confused whilr determinig the pressure.
well the situation was that a block is immersed in water. the height of water column above it is .05m. the blocks side is .02 m and its base area is 25cm^2.and the height of water below the block is not given.
the presure on top of the block was simply the application of formula 'pgh' = 500pascal.
but how do i determine the pressure on the lower surface ?
also in general while determinig pressure on lower surface i THINK that we consider the height of water column from the upper edge of block to the bottom of the water container.
if this is true then why?
explain
From your picture it looks to be .07m
yes the question was solved in my book using .07m
but why? i mean we have to find the pressure acting on the lower surface. so why not consider the height of water under it?
i don't understand this point.
It's the weight of the water above (and the weight of the atmosphere above that!) that is is creating the pressure at any given depth. The water below only provides a "surface" upon which the weight acts to manifest the pressure. If this were not the case the oceans would leap from their beds, there being no water above them to hold them down against the pressure of all that water below the surface level :smile:
ok...you have a point
but then according to what you are saying , the pressure on the lower surface should also be in the lower direction and thus there will be no upthrust. pressure on both surfaces will be directed downwards...
also i remeber when i was in 8th grade there was a problem similar to this one and the book authors while computing pressure on lower surface considered the water column to be = height of block+water under it
so i am all confused...explain a bit more
Pressure is caused by the weight of the material above, but it isn't weight itself. Gases and liquids are composed of highly mobile particles that distribute the force in all directions. The weight of the material above sets the magnitude of the distributed force at any given depth.
Pressure on an immersed object is always directed inwards, normal to the surface of the object. Upward facing, downward facing, sideways, or slanted, it makes no difference.
The problem you're remembering must have used a coordinate system that had its origin at the bottom of the container, and likely determined the depth as the difference between a given height in the column and the height of the surface.
ok ...thanks
i never really knew that pressure was always directed normally inwards
now i understand that pressure in other words is a distributive force due to weight of material above it
so by above understanding the pressure on lower surface is also directed inwards or in other words:it is directed uipwards and its magnitude is more than at the top surface
thanks
khurram usman said:
ok ...thanks
It's just the way fluids work (and hence don't hold their shape) -- they try to distribute forces in every direction they can, on any surface available.
FAQ: Pressure on block immersed in water?
What is the formula for calculating the pressure on a block immersed in water?
The formula for calculating the pressure on a block immersed in water is P = ρgh, where P is the pressure, ρ is the density of the fluid (water), g is the acceleration due to gravity, and h is the depth of the block in the water.
How does the pressure on a block immersed in water change as the depth increases?
The pressure on a block immersed in water increases as the depth increases. This is because the weight of the water above the block increases, creating a higher force and therefore a higher pressure.
Can the pressure on a block immersed in water be negative?
No, the pressure on a block immersed in water cannot be negative. Pressure is defined as the force per unit area, so it cannot have a negative value. It can only be zero or a positive value.
How does the shape and size of the block affect the pressure on it when immersed in water?
The shape and size of the block do not affect the pressure on it when immersed in water. The pressure is solely dependent on the depth of the block and the density of the water, as stated by the formula P = ρgh.
What is the difference between pressure and buoyant force on a block immersed in water?
Pressure is the force per unit area applied by a fluid on an object immersed in it, while buoyant force is the upward force exerted by a fluid on an object immersed in it. Pressure acts in all directions, while buoyant force only acts in the upward direction. The pressure on a block immersed in water is caused by the weight of the water above it, while the buoyant force is caused by the displacement of the water by the block.
