Pressure or force in piston cylinder
In summary, pressure in a piston cylinder is the force per unit area exerted by the gas or fluid inside the cylinder on the walls of the cylinder. It can be calculated using the equation P = F/A, where P is pressure, F is the force exerted by the gas or fluid, and A is the area of the piston. The pressure and force in a piston cylinder are directly proportional, meaning that an increase in force will result in an increase in pressure and vice versa. Temperature can also affect pressure in a piston cylinder, with an increase in temperature resulting in an increase in pressure. Other factors that can affect pressure and force in a piston cylinder include the type of gas or fluid, temperature, volume, force applied, atmospheric pressure
GREWAL
how can i find pressure or force in piston cylinder if i have...
crank speend=5000rpm
crank shaft throw=42mm
piston diameter=95mm
piston gudgeon mass=500g
i know cylinder diameter=bore...
is crank throw=stroke?
What pressure? What force?
Related to Pressure or force in piston cylinder
1. What is pressure in a piston cylinder?
Pressure in a piston cylinder is the force per unit area exerted by the gas or fluid inside the cylinder on the walls of the cylinder. It is typically measured in units of pressure, such as pounds per square inch (psi) or pascals (Pa).
2. How is pressure calculated in a piston cylinder?
The pressure in a piston cylinder can be calculated using the equation P = F/A, where P is pressure, F is the force exerted by the gas or fluid, and A is the area of the piston. This equation assumes that the force is evenly distributed over the entire area of the piston.
3. What is the relationship between pressure and force in a piston cylinder?
The pressure and force in a piston cylinder are directly proportional. This means that as the force applied to the piston increases, so does the pressure inside the cylinder. Similarly, a decrease in force will result in a decrease in pressure.
4. How does temperature affect pressure in a piston cylinder?
According to the ideal gas law, an increase in temperature will result in an increase in pressure, assuming that the volume and number of moles of gas remain constant. This is because an increase in temperature causes the gas molecules to move faster and collide with the walls of the cylinder more frequently, resulting in a higher pressure.
5. What factors can affect the pressure or force in a piston cylinder?
The pressure and force in a piston cylinder can be affected by several factors, such as the type of gas or fluid inside the cylinder, the temperature, the volume of the cylinder, and the force applied to the piston. Additionally, external factors such as atmospheric pressure and friction can also impact the pressure and force in a piston cylinder.
  • Mechanical Engineering
