Pressure: Sealed bottle physics
  • I
  • Thread starter SteveA001
  • Tags
    Pressure
In summary, "Pressure: Sealed bottle physics" explores the principles of pressure and its effects within a sealed bottle. It discusses how gas laws govern the behavior of gases under varying temperatures and volumes, leading to changes in pressure. The content highlights practical experiments and real-life applications, illustrating the importance of understanding pressure dynamics in everyday objects like sealed bottles.
SteveA001
TL;DR Summary
If a bottle is partially filled with hot water and sealed, together what some air, what happens to the pressure inside the bottle as it cools to room temperature? Assumptions: The temperature of the air in the bottle will initially be about the hot water temperature as the bottle is first sealed, and the pressure inside will also equal the outside air pressure as the bottle is sealed. I notice my vacuum flask does not appear to build up a noticeable vacuum as I open it after my coffee has cooled, and the same lack of vacuum appears with a zip bag filled with water as it cools (no balloons handy unfortunately). So on the one hand experiment appears to indicate that a vacuum is not created, but on the other hand, would the pressure inside the bottle not be at water vapour pressure, which lowers as the temperature drops, and which starts at ambient pressure?
It is my experience that when pouring hot liquid in a thermal flask and wait until it eventually cooled, there is a noticeably lower pressure when I open it. So maybe your vacuum flask wasn't as sealed as you hoped? In theory you can also have some outgassing of the liquid due to the lower pressure which undoes the lower pressure, but I don't know how strong that effect can be since boiling usually removes a lot of dissolved gasses.
There is not an actual vacuum of course after cooling. The lower temperature makes the density of air to want to become larger again, but since that's not possible you get a lower pressure instead. This does explain why the zip-bag doesn't work, the zip-bag can change shape and thus accommodate the lower density by decreasing the volume of the air.
The water vapor pressure has nothing to do with this. It is the temperature and pressure at which water vapor condenses again. Unless, of course, a significant part of air was replaced by water vapor which then condenses. That actually would generate quite a strong 'vacuum'.
(For me a 'vacuum' is still equivalent to 'no air at all' but apparently it is often used to mean 'pressure lower than atmospheric')
Likes russ_watters
This is not correct. When the lid is fastened, the total pressure in the container is 1 atm., and it is comprised of the water vapor in the head space at a partial pressure equal to its equilibrium vapor pressure at the temperature of the hot liquid, and air in the head space at a partial pressure of 1 atm. minus the partial pressure of the water vapor. When the system cools, most of the water vapor condenses, leaving water vapor in the head space at a much lower partial pressure, equal to the equilibrium vapor pressure of the much cooler liquid in the container. The pressure in the head space also decreases a little because the partial pressure of the air decreases a little. But, the dominant effect is water vapor condensing from the gas phase. This is the basic principle behind vacuum sealing of items like soup cans and preservatives.
Likes russ_watters, jbriggs444, gmax137 and 1 other person
Ah, yes. I have just tried it with a plastic bottle and it did indeed deform as it cooled, indicating a pressure drop, as you say. It appears I was distracted by my vacuum flask, strange that it doesn't appear to pop or offer resistance when opened when cooled. My original interest was in the magnitude of the vacuum created in such a set up? How would it be calculated? I hit upon differences in vapour pressure, before being distracted by my flask, but you say that is not the way to go anyway?
I do say that the vapor pressure change is key to this. Why don't I help you get started in modeling this. Suppose I have a rigid bottle of total volume V an a head space of v. Assume that air does not significantly dissolve in the liquid water. Let the initial temperature be 160 F. What is the specific volume of liquid water at this temperature? What is the equilibrium vapor pressure of water at this temperature? What is the specific volume of water vapor at this temperature? In terms of V, what is the mass of water in the container? What is the partial pressure of air in the head space?
Likes Lord Jestocost
I think the assumption that the water vapor partial pressure is at equilibrium isn't necessarily the case. It likely depends on the geometry of the bottle and how long between when you pour in the liquid and seal it but in general I think it would be something less.
This is also how some sealing methods in home canning work.
https://en.wikipedia.org/wiki/Weck_jar
You think that? Have you done any calculations to quantify this?
Likes gmax137
Likes russ_watters
Ah, yes. I have just tried it with a plastic bottle and it did indeed deform as it cooled, indicating a pressure drop as you say. It appears I was distracted by my vacuum flask performance. Strange that it doesn't appear to pop or offer resistance when opened. My original inquiry, before was the magnitude of the vacuum How would it be calculated? I hit upon differences in vapour pressure, before being distracted by the flask, but you say that is not the way to go anyway?
What is the specific volume of liquid water at this temperature? 1000 kg/m^3
What is the equilibrium vapor pressure of water at this [114 C] temperature? 166,000 Pa
What is the specific volume of water vapor at this temperature? 1 kg/m^3
In terms of V, what is the mass of water in the container? 1000(V-v) kg
What is the partial pressure of air in the head space? Presumably it rises with temperature, as does the proportion of water vapour?
SteveA001 said:
Ah, yes. I have just tried it with a plastic bottle and it did indeed deform as it cooled, indicating a pressure drop as you say. It appears I was distracted by my vacuum flask performance. Strange that it doesn't appear to pop or offer resistance when opened. My original inquiry, before was the magnitude of the vacuum How would it be calculated? I hit upon differences in vapour pressure, before being distracted by the flask, but you say that is not the way to go anyway?What is the specific volume of liquid water at this temperature? 1000 kg/m^3
160 F is 71.1 C. The equilibrium vapor pressure of water at this temperature is 32700 Pa
From the steam tables, 4.84 kg/m^3
$$m=\frac{(V-v)}{0.001}+\frac{v }{4.84}$$
p=100000-32700=67300 Pa
OK so far?
Likes russ_watters
D'oh, I googled rather than calculating.
I found a table online(https://www.thermexcel.com/english/tables/vap_eau.htm), added an exponential trend line in Excel and got this formula: Specific volume (steam) = 1.6888*(AbsolutePressureInBar)^-0.942. This agrees with your value for 0.327 bar.
Chestermiller said:
$$m=\frac{(V-v)}{0.001}+ \frac{v}{4.84}$$
I see.
OK so far?
Well, I guess given that you calculated masses in the previous paragraph the answer isn't as simple as subtracting the above from atmospheric pressure, leaving a third of a bar. So my puzzle now is to relate mass to pressure.
I see.
If the total pressure is 1 bar = 100000 Pa, and the water vapor partial pressure is 32700 Pa, the partial pressure of the air is 67300 Pa.
You now cool the container and its contents to 20 C. What is the equilibrium vapor pressure of water at 20 C? Assuming the changes in the volume of liquid water is negligible when part of the water condenses, what is the partial pressure of the air when it is cooled from 71.1 C to 20 C? What is the total pressure at 20 C?
No, wouldn't know how to do that.
But I did a couple of kitchen experiments to test this a few years ago. I poured near-boiling water into a small jar, placed the lid loosely on top, and then after 10-15 seconds I screwed the lid tight. When cooled to room temperature I inverted the jar in a basin of water and unscrewed the lid, allowing water to enter because of the vacuum created. Then I sealed it again, dried it off, and weighed it. I assumed that the initial air temperature was initially the same as the water temperature, which is probably not quite true. And I figured that the water vapor partial pressure was effectively zero at room temperature.
The water temperature in the jar was initially about 90°C. At that temperature equilibrium vapor pressure is 0.7bar. But the amount of water that entered the inverted jar suggested that the water vapor partial pressure was actually about 0.5bar. In another test where I screwed the lid down immediately it was only 0.4bar.
The diffusivity of water vapor in air is about 0.25 cm^2/sec. If the head space is about 1 cm thick, it would take about 4-10 seconds for the water vapor to equilibrate (and purge the corresponding amount of air from the head space). In your experiment, while the lid was being set in place, maybe the lid was put in place very rapidly and the air partial pressure was closer to 1 bar to start, and when the water vapor equilibrated, the total pressure in the bottle was higher than 1 bar. But, putting the lid on gradually, as is usually the situation in canning operations, would virtually guarantee that the partial pressure of the air in the head space is 1 bar minus the equilibrium vapor pressure of the water.
~2350 Pa
I'm still coming to grips with the concept of partial pressures, having only seen it in relation to parts of air rather than to the entire air. Based on the earlier example partialPressureOfAirInHeadspace = totalPressure - 2350? Is it something that can be found from lookup tables?
partialPressureOfAirInHeadspace + 2350?
SteveA001 said:
~2350 Pa
No. Based on the ideal gas law, partial pressure of air in cooled sealed container = ##67300\frac{273+20}{273+71}=57300\ Pa##. So the total pressure in the quenched container is 57300 + 2350 = 59700 Pa. This is 60% of the 1 bar pressure that was present when the lid went on at 71 C. Quite a vacuum!!
Likes SteveA001
Sneaky, p1/t1= p2/t2. So if the initial temperature were 95C the vacuum would be 15% of atmospheric pressure. And at 100 C it would be 1 atmosphere of vacuum.
But did we use the specific volume of water vapor (4.84 kg/m^3) and the mass calculated earlier?
We would take those into account if we wanted to include the effect on the air partial pressure of the change in liquid volume as a result of condensation.
Oh, that would be a small effect then.
Thanks for your help.
Now that the answer is quantified, lots of everyday observations can be explained. For example why vacuum flasks and hot water bottles have hard screw tops. I am also testing a preheated vacuum flask with large airspace and little liquid to see if a near 1-atmosphere vacuum in a 0.5-litre flask can make a pop when cooled and opened. I wonder also whether these equations could be tested by seeing how much water is sucked into the flask submerged in water as it is opened.
No, the lid was placed gently on the jar.
Do the experiment yourself at home. All you need is a jar and a scale and a sink. Plus the willingness to waste thirty minutes or so which (like me) you clearly have since you post here :-)
OK. Here is the detailed model and how it plays out.
Let ##v_L(T)## = specific volume of saturated liquid water at temperature T
##v_V(T)## = specific volume of saturated water vapor at temperature T
##P^*(T)## = equilibrium vapor pressure of water at temperature T
V = volume of container
v = volume of head space at initial temperature ##T_H##
##T_H## = Initial high temperature when lid is put in place
##T_C## = final cold temperature
##p_{atm}## = atmospheric pressure
INITIAL HIGH TEMPERATURE
partial pressure of water vapor = ##P^*(T_H)##
partial pressure of air in heat space = p_{atm}-##P^*(T_H)##
mass of water in can = m = ##\frac{V-v}{v_L(T_H)}+\frac{v}{v_V(T_H)}##
FINAL LOW TEMPERATURE
$$m(1-x)v_L(T_C)+mxv_V(T_C)=V$$where x = mass fraction vapor in final state. Solving for x gives: $$x=\frac{\frac{V}{m}-v_L(T_C)}{v_V(T_C)-v_L(T_C)}$$
Volume of gas phase in final cold state = ##mxv_V(T_C)=mv_V(T_C)\frac{\frac{V}{m}-v_L(T_C)}{v_V(T_C)-v_L(T_C)}##
Partial pressure of air in final state = ##[p_{atm}-P^*(T_H)]\frac{T_C}{T_H}\frac{v}{mv_V(T_C)\frac{\frac{V}{m}-v_L(T_C)}{v_V(T_C)-v_L(T_C)}}##
Partial pressure of water vapor in final state = ##P^*(T_C)##
Nice work. I've run some numbers through it, in Excel. Using the same temperatures as before (71C to 20C) for a flask 98% full of water and then 2% full, producing answers of 30% of atmospheric pressure and 60% (the second one being same as before, when not taking condensation into account). Basically condensation can't be ignored when the flask is full, which is counter-intuitive?
So how to maximise the pop when opening a container for a given temperature. One extreme gives high vacuum with little volume, and the other a high volume of little vacuum. Hmm.
Not really. Condensation compresses the air.
Did you mean ##v## here instead of v?
JT Smith said:
Did you ##v## here instead of v?
They're the same.
I redid my little kitchen experiment this morning, being more careful to allow enough time for the vapor to equilibrate. I left the lid off for about 15 seconds and then placed it on the jar with just a crack open for another 15 seconds. Then I sealed it.
When I originally did this I wasn't being rigorous with the calculations as I was mostly interested in the final result: how much pressure was in the container after it cooled. One thing I didn't include was the fact that the liquid would contract by a small but significant amount.
So using your detailed model I crunched the numbers. Can you check to see if I did it right? I'd appreciate it.
I got a total pressure of 0.23 bar using the following values.
V = 237.9 ml
##v## = 39.5 ml
##T_H## = 90°C
##T_C## = 15°C
##p_{atm}## = 1.004 bar
##v_L(T_H)## = 1.036 ml/g
##v_V(T_H)## = 2359.1 ml/g
##P^*(T_H)## = 0.702 bar
##v_L(T_C)## = 1.000 ml/g
##v_V(T_C)## = 77875 ml/g
##P^*(T_C)## = 0.017 bar
V = 237.9 ml
##v## = 39.5 ml
##T_H## = 90°C
##T_C## = 15°C
That's roughly what I get using your numbers. Then I think you add 'Partial pressure of water vapor in final state' to 'Partial pressure of air in final state' to get 'Total pressure in the quenched container', making 22800 Pa, or 22.7 % of atmospheric pressure.
An Excel sheet is attached, if this site permits.
  • thermosFlask.xlsx
Thank you. I'm glad I didn't screw up the math.
My experimental results are still at odds with the model however. I calculate an initial water vapor partial pressure of about 0.5 bar instead 0.7 bar, essentially the same as what I'd determined with a much rougher model. So either I'm making some poor assumption, screwing up the actual work, or your model is an idealization that doesn't always hold in the real world.
You are an esteemed scientist and I'm just some guy on the internet so the good money would be placed on you being right. I'm often wrong. I just can't see what I'm screwing up.
One other thing: I noticed that the headspace temperature wasn't the same as the water. Even when I sealed up the opening with plastic and put an oven mitt over it to insulate it was still about 10°C lower. When the vapor and liquid are not in thermal equilibrium how do you determine the vapor pressure?
I recall reading a paper years ago where the author couldn't fit the data in his system using the water temperature in his model. But using the vapor temperature gave a great fit. He never justified that choice via first principles, he just kind of went with it. If I do the same it seems to work for me too. That is, if I use the saturated pressure for the headspace temperature instead of the water temperature the model is a pretty close match to what I measured. That is, the saturated vapor pressure at 80°C is roughly 0.5 bar.
FAQ: Pressure: Sealed bottle physics
What happens to the pressure inside a sealed bottle when it is heated?
When a sealed bottle is heated, the pressure inside the bottle increases. This is because the temperature of the gas inside the bottle rises, causing the gas molecules to move faster and collide with the walls of the bottle more frequently and with greater force. According to the ideal gas law (PV=nRT), if the volume (V) is constant and the amount of gas (n) remains the same, an increase in temperature (T) will result in an increase in pressure (P).
Can a sealed bottle explode if the pressure inside becomes too high?
Yes, a sealed bottle can explode if the pressure inside becomes too high. If the internal pressure exceeds the structural limits of the bottle, the bottle can rupture or burst. This is why it's important to avoid exposing sealed bottles to high temperatures or overfilling them with gas or liquid, as this can significantly increase the internal pressure.
How does cooling a sealed bottle affect the pressure inside?
Cooling a sealed bottle decreases the pressure inside. As the temperature drops, the kinetic energy of the gas molecules inside the bottle decreases, leading to fewer and less forceful collisions with the walls of the bottle. According to the ideal gas law, if the volume (V) and the amount of gas (n) remain constant, a decrease in temperature (T) will result in a decrease in pressure (P).
Why does a sealed bottle sometimes make a noise when opened?
A sealed bottle makes a noise when opened because of the sudden release of pressure. When the seal is broken, the pressurized gas inside the bottle rapidly escapes to equalize with the external atmospheric pressure. This rapid movement of gas creates a sound, often heard as a "hiss" or "pop."
How does the type of liquid inside a sealed bottle affect the internal pressure?
The type of liquid inside a sealed bottle can affect the internal pressure due to differences in vapor pressure. Different liquids have different vapor pressures, which is the pressure exerted by the vapor in equilibrium with its liquid at a given temperature. For example, a bottle containing a liquid with a high vapor pressure will have a higher internal pressure compared to a bottle with a liquid of low vapor pressure, assuming the temperature is the same. Additionally, the presence of dissolved gases in the liquid can also influence the internal pressure.
