Pressure-temperature graph without zero y-intercept
  • Thread starter robcowen
  • Tags
    Graph Zero
In summary, the conversation was about a high school physics teacher conducting an experiment using a manometer to measure the pressure of air in a boiling tube. The teacher recorded the head difference in mm and converted it to metres using the pressure formula. They also added the local atmospheric pressure to get the absolute pressure of the air. However, the results did not match the theoretical pressure and the teacher was puzzled. Possible sources of error were discussed, including using a boiling tube as a gas reservoir and using a thermometer in the water bath instead of in the boiling tube. The teacher also shared their updated calculations and equipment used. One suggestion was to use a mercury-filled manometer instead of one filled with water to get a more accurate reading.
robcowen
I am a high school physics teacher and I've been trying out an experiment for my students. I used a manometer (a plastic tube in a U-shape partially filled with water) to measure the pressure of the air in a boiling tube. I placed the boiling tube into a beaker of water and varied the temperature. I recorded the head difference in mm and converted this to metres.
I used (pressure = density of water x 9.81 x head) to work out the pressure (relative to atmospheric pressure). I then added the local atmospheric pressure (sourced from BBC Weather in millibars and converted to Pa) to the relative pressure to get the absolute pressure of the air.
I plotted a graph of temperature (in Kelvin) against absolute pressure (in Pa) and got a nice straight line relationship. However, my y-intercept should be at zero, according to the ideal gas laws, but is actually crossing at around 90,000 Pa.
Either my gradient is much too shallow (my points are very close to the line of best fit) or I have an absolute error that has shifted my results up the y-axis. The most likely source of this is the atmospheric pressure.
I'm very puzzled and have probably made a silly error somewhere. If you're interested in checking my numbers, please have a look at the attached spreadsheet.
Thanks,
Rob
  • Trial results.xlsx
Science news on Phys.org
Did you use some large gas reservoir in the experiment?
If your gas is in the tube only, the moving water level will change its volume significantly, together with its temperature.
That is something that concerned me, although I would expect a changing volume to cause the line to curve.
The temperature measurement may also be a source of error. I did have a thermometer in the boiling tube, but decided instead to use the one in the water bath. This was because the gas appeared to expand almost immediately (and settle) after the boiling tube was placed in the bath, whereas the thermometer in the boiling tube responded very slowly. This would suggest to me that the rate of heat transfer was much faster through the wall of the boiling tube than it was between the warmed air and the thermometer, so the thermometer in the water bath was more representative of the air temperature than the thermometer in the boiling tube.
Not significantly, if the volume change is the dominating effect.
Assuming a constant width of the pipe, I get a nice match if the air has a height of 1500mm above your zero-point.
Likes 1 person
What do you mean by this?
I've done some calculations of the theoretical pressure (pV=nRT) and get a gradient of 346 (as opposed to 42 for the experimental results). I've also built into my calculations an allowance for the change in volume of the air within the manometer - this changes the gradient to 228.
I'm just very perplexed by how far off these results are. I used a boiling tube as the gas reservoir. I've estimated the volume of boiling tube and pipework to be about 64ml, with the changing volume in the manometer being no more than around 3ml. Significant, but it shouldn't dominate.
I've attached my updated calculations (including theoretical pressure) and a photo of the equipment I used.
Any ideas would be greatly appreciated!
If the manometer is filled with water then you are not measuring the pressure of air but the pressure of air saturated with water vapour.
You should be using a mercury filled manometer.
Related to Pressure-temperature graph without zero y-intercept
1. What is a pressure-temperature graph without a zero y-intercept?
A pressure-temperature graph without a zero y-intercept is a graph that does not cross the y-axis at zero. This means that the graph does not start at zero pressure and temperature, but rather at some other values.
2. Why would a pressure-temperature graph not have a zero y-intercept?
There are several reasons why a pressure-temperature graph may not have a zero y-intercept. It could be due to experimental error, incomplete data, or a non-linear relationship between pressure and temperature.
3. How is a pressure-temperature graph without a zero y-intercept different from a standard graph?
A pressure-temperature graph without a zero y-intercept is different from a standard graph in that it does not start at the origin (0,0). This means that the relationship between pressure and temperature may not be directly proportional, as it would be in a standard graph.
4. What can a pressure-temperature graph without a zero y-intercept tell us?
A pressure-temperature graph without a zero y-intercept can still provide valuable information about the relationship between pressure and temperature. It can show if there is a linear or non-linear relationship, and the slope of the graph can still indicate the change in pressure per unit change in temperature.
5. How can a pressure-temperature graph without a zero y-intercept be useful in scientific research?
In scientific research, a pressure-temperature graph without a zero y-intercept can be useful in understanding the behavior of gases and how they respond to changes in pressure and temperature. It can also help in identifying any experimental errors or anomalies in the data. Additionally, it can be used to determine the critical point of a gas, which is the temperature and pressure at which it transitions from a gas to a liquid state.
  • Thermodynamics
