Prevent a robotic cleaner from climbing on a block of iron with a magnet?
  • I
  • Thread starter CharlesT
  • Tags
    Magnet
In summary, to prevent a robotic cleaner from climbing on a block of iron, a magnet can be strategically placed to create a magnetic field that repels the robotic cleaner, ensuring it remains at a safe distance from the iron surface.
CharlesT
Hi,
very trivial question, sorry, but I did not find the answer on the net.
I have a robotic vacuum cleaner,
https://i02.appmifile.com/248_operator_sg/07/03/2023/b083a6129f828ac367c4600b0a78b85b.jpg?f=webp
and it's constantly bumping into and trying to climb on the massive iron one-pilar foot (ca. 30KG for the black iron base plus ca. 30 kg for the (surprisingly magnetic) stainless steel iron leg above) of a modern style dining table like this one:
https://immagini.designbest.com/immaginiprodotti/tavoli/big/3978-tavoli-70280-b-1.jpg
Now that cleaner like most of them has a magnetic field detector to prevent access to some zones and I could stick a magnetic strip like this:
https://www.aliexpress.com/item/1005002319655397.html?spm=a2g0o.productlist.main.1.32c02760OKW1JR&algo_pvid=a99932be-9305-49f8-8d7e-13e453009eef&aem_p4p_detail=202311170449327399213835089200000957758&algo_exp_id=a99932be-9305-49f8-8d7e-13e453009eef-0&pdp_npi=4@dis!USD!16.94!11.69!!!16.94!!@2103872a17002253728037584e2761!12000020067648197!sea!FR!712444402!&curPageLogUid=hfGIY1yuXvTB&search_p4p_id=202311170449327399213835089200000957758_1
all around that iron block, but it would not be very nice looking (tried it, plus the bands do not stick well).
So I'm wondering whether sticking on the table iron base, permanently, a strong neodymium magnet could magnetize the block sufficiently to make the robot detect it like it does detect these bands, and if so how strong that magnet should be...
Any help appreciated, thanks!
Charles
This seems awfully hard. Don't you have little IR transmitters you can place on the floor near areas you want excluded? Why invent your own solution when a trip the store will solve it in half an hour?
The IR is not adapted, it’s on the floor and I just want to exclude the base.
The magnetic band could be a solution as I said but I was wondering if magnetizing the bloc could not be a more original and elegant solution.
But to be frank I’m investigating this mostly for the fun of it and for the fun of learning something on magnetic fields: what is the threshold of the detectors mounted on the robot, the strength of the field of such a band and what is the relation between the magnetic field of a magnet and the one created within another material when the magnet is placed on it…
Experiment. Place a magnet on the floor and watch the robot's response.
The table base looks like it is made from cast iron. One might magnetise that during manufacture, but it would be difficult after the event. A magnetised base would be difficult to clean of magnetic grit before painting.
I would consider sticking small magnets to the periphery of the base. Experiment with all the same polarity, or alternating but spaced apart.
Maybe a coil wound around the circumference of the base, with DC current flow, would work to produce a vertical magnetic field outside the base.
The non-magnetic solution would be to raise the base, using 8 or more black rubber feet, by a few millimetres, sufficient to stop the robot climbing. Sticking magnets under the base might achieve the same outcome, and produce the keep-out warning field.
Alternatively, making a short cylindrical skirt, that sits outside the base of the table to form a wall, would stop the robot. You could make it from a strip of metal, plastic, or card, painted to match the base. It would need tabs under the table base edge, to hold it down.
Thanks, yes, I already had these elements in mind but for aesthetic and practical reasons they would not be adapted.
The preferred idea would really be to use a big magnet, put it permanently on the iron base, and have that one thus get magnetized sufficiently to have the robot cleaner detect its magnetic fiedl.
The question is: is this possible, or willthe magnetic field in all cases be to weak?
Also how does one calculate the magnetic field a magnet can indice in a given mass of iron?
Now even if I'd like to understand the theory before, I'm ready to experiment, but for that I'd like to have some idea of the size of the magnet needed, so not to invest blindly in something too small...
Unless you know:
1. The sensitivity of the robot magnetic field detector, and
2. The strength and field pattern of a magnet,
you will be unable to solve this problem numerically.
Find a cheap magnet from anywhere.
Place it on the floor and watch the robot response.
Not very expensive and worth a punt if you like experimenting. Trouble is that it could look pretty naff. Depending on your metal or wood working skills, you could make a hoop of the appropriate depth that could fit around the base actually look as though it's part of the design.
I can see problems with a permanent magnet sitting on the floor; It could accumulate loads of steel bits.
easy to experiment with thick card for a design first and then go for more permanent material.
or how about a disc to sit the base on to raise the step? Ebay has all sorts of wood and metal shapes available.
Thanks for the advice but this I already knew and is not an answer to my questions.
Never mind, just forget it.
This is always a potential problem with 'agony aunt' topics like this one. Every contributor needs to go over the same ground, mentally as the OP. But sometimes someone else's journey can throw up something extra.
In fact, you have a double problem because you want to keep the aesthetics and none of the possibilities would ensure that. The only viable solution would be to check that a magnetic system would work then to permanently magnetise the base itself. If you are lucky the base may be in two parts - a shiny stainless cover and a massive iron base. The internals of the base could be magnetisable (or replaceable) on its own without spoiling the shine of the cover.
FAQ: Prevent a robotic cleaner from climbing on a block of iron with a magnet?
How can I prevent a robotic cleaner from climbing onto a block of iron using a magnet?
To prevent a robotic cleaner from climbing onto a block of iron using a magnet, you can adjust the magnetic field strength or orientation to create a repulsive force or shield the iron block with a non-magnetic material that disrupts the magnetic attraction.
What materials can be used to shield the iron block from the magnetic attraction?
Materials such as aluminum, copper, or specialized magnetic shielding materials like Mu-metal can be used to shield the iron block from the magnetic attraction. These materials can help to redirect or absorb the magnetic field, reducing the attraction between the robot and the iron block.
Can altering the design of the robotic cleaner help in preventing it from climbing on iron blocks?
Yes, altering the design of the robotic cleaner can help. For example, incorporating sensors that detect iron blocks and programming the cleaner to avoid them, or designing the cleaner with non-magnetic wheels or components that reduce the magnetic attraction can be effective solutions.
Is it possible to use software solutions to prevent the robotic cleaner from climbing on iron blocks?
Yes, software solutions can be used. By integrating sensors and implementing algorithms that detect the presence of iron blocks, the robotic cleaner can be programmed to avoid these areas. This can be achieved through path planning and obstacle avoidance techniques.
How does the strength of the magnet affect the robot's ability to climb on iron blocks?
The strength of the magnet plays a crucial role in the robot's ability to climb on iron blocks. A stronger magnet will create a stronger attraction, making it more likely for the robot to climb onto the iron block. Reducing the magnetic field strength or using a magnet with adjustable strength can help in preventing this behavior.
