qazadex
- 4
Not sure if this is in the right section, but anyway...
Explain the primary cause of the force experienced by the rod. In your explanation you must
refer to the magnetic field generated by the current.
The rod is carrying current perpendicular to the magnetic field created by two magnets.
F=QvB, F=BIL
So the first thing that came to mind was using one of the aforementioned equations as an explanation, saying that since the current is perpendicular to the magnetic field and therefore a force would be produced. However, the answer is as follows:
Owing to the moving charges of the current in the conducting rod, a magnetic field is
generated in accordance with the right-hand grip rule. This magnetic field then superimposes
onto the external magnetic field, resulting in a net magnetic field that has a varying intensity.
The conductor then experiences a force in the direction of the weaker region of the field and
the direction is given by the right-hand slap rule.
I can't wrap my head around this. How does the induced magnetic field interact with the external magnetic field to create a net magnetic field perpendicular to the direction of the external magnetic field? Since the magnetic fields are vectors, surely if a wire did not have an upwards or downwards force on it, how does a magnetic field acting on a wire in equilibirum have an effect perpendicular to it?
Sorry if this was confusing, and thanks for any answers.
F=QvB, F=BIL
