Undergrad Prime and Maximal Ideals in PIDs ... Rotman, AMA Theorem 5.12
  • Thread starter Thread starter Math Amateur
    Prime Theorem
The discussion centers on understanding the proof of Theorem 5.12 from Rotman's "Advanced Modern Algebra," specifically regarding the implications of an irreducible element p in a prime ideal context. Participants clarify that if p is irreducible and divides a, then either a and p are associates or a is a unit. The reasoning hinges on the properties of prime ideals, where if a does not belong to the ideal, it leads to a contradiction that forces a to be a unit. The conversation emphasizes the connection between the irreducibility of p and the structure of prime ideals in principal ideal domains (PIDs). Overall, the analysis confirms the correctness of the interpretations and reasoning presented.
Math Amateur
MHB
I am reading Joseph J. Rotman's book: Advanced Modern Algebra (AMA) and I am currently focused on Section 5.1 Prime Ideals and Maximal Ideals ...
I need some help with understanding the proof of Theorem 5.12 ... ...Theorem 5.12 reads as follows:
In the above text Rotman writes the following:" ... ... If ##(p) \subseteq J = (a)##, then ##a|p##. Hence either ##a## and ##p## are associates, in which case ##(a) = (p)##, or ##a## is a unit, in which case ##J = (a) = R##. ... ... ... "My question is as follows:Rotman argues, (as I interpret his argument), that ##a|p## implies that either ##a## and ##p## are associates ... or ... ##a## is a unit ...Can someone please explain (slowly and clearly
) why this is the case ... ... ?Hope someone can help ... ...
Peter
I have been reflecting on my question and believe the answer is something like the following:Firstly ... we are given that ##p## is irreducible ...
Now ... ##p## irreducible
##\Longrightarrow p## is non-zero and ##p## not a unit ... and ... where ##p## equals a product,
say, ##p = ra## ... then one of ##a## and ##r## is a unit ...Now, ##a|p \Longrightarrow p = ra## for some ##r \in R##
So then we have that:
##p## irreducible and ##p = ra \Longrightarrow## one of ##a## and ##r## is a unit ...
If ##r## is a unit then ##a## and ##p## are associates ... ...
... otherwise ##a## is a unit ...
Can someone confirm that this is correct ... or alternatively point out shortcomings and errors in the analysis ...
Peter
We have ##a|p## so ##p=ba## for some ##b##. Since ##p\in I=(p)## and ##I## is a prime ideal, it must be the case that either ##a## or ##b## is in ##I##.
If ##a\in I## we have ##p|a## which, together with the earlier-observed ##a|p## makes ##p,a## associates.
If ##a\not\in I## then ##b\in I## in which case ##b=pc## for some ##c##. So ##p=pca##. We write this as
$$0=p-pca=p(1-ca)$$
and since ##p\neq 0## and a PID is an Integral Domain, we must then have ##1-ca=0##, whence ##ca=1## so ##a|1##, making ##a## a unit.
Likes Math Amateur
That reasoning looks sound to me. It's a different route from mine, as yours explicitly uses the irreducibility of ##p## whereas mine uses the primeness of the ideal ##I##. I suspect the connection between the two lies in the proof of Proposition 5.6. But either one will suffice.
Likes Math Amateur
Thanks Andrew ... your posts were REALLY helpful ...
Appreciate your help on this issue ...
Peter
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
