MHB Prime numbers vs consecutive natural numbers.
All odd numbers can be expressed as the sum of consecutive natural numbers, while prime numbers (except for 2) can only be represented as the sum of two consecutive natural numbers. The sum of k consecutive natural numbers results in specific modular conditions, limiting viable candidates for k to 1 or 2. This leads to the conclusion that odd primes can be expressed as sums of two consecutive numbers, such as 7 = 3 + 4. The discussion emphasizes the unique property of prime numbers in relation to sums of consecutive natural numbers.
mente oscura
An easy question.
All "odd" number can be expressed as a sum of consecutive natural numbers.
Example:
35=17+18
35=5+6+7+8+9
35=2+3+4+5+6+7+8Question:
Demonstrate that prime numbers (except for the "2"), can only be expressed as the sum of two consecutive natural numbers.
Mathematics news on Phys.org
Re: prime numbers vs consecutive natural numbers.
Elementary. Sum of $k$ consecutive natural numbers is either $0 \pmod{k}$ or $0 \pmod{k/2}$ so the only plausible candidates are $k = 1$ and $k = 2$ which is easy to verify for odd primes.
mathbalarka said:
Sum of $k$ consecutive natural numbers is $0 \pmod{k}$ so the only plausible candidate is $k = 1$ which is easy to verify for odd primes.
7=3+4 \rightarrow{} k=2
Look at it again.
the question should be
Demonstrate that only prime numbers (except for the "2"), can be expressed as the sum of two consecutive natural numbers only.
let the number of numbers be n and 1st number a+1
then sum of numbers= an + n(n+1)/2
it is integer
if n is odd (n+1)/2 is integer so it is divsible by n
if n is even an and n(n+1)/2 is divisible by n/2
so if n > 2 and odd it is not prime as divsible by n
if n > 2 and even it is divisible by n/2(which is >= 2) so not prime
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
