Math Amateur
MHB
- 3,998
- 48
Dummit and Foote on page 284 give the following definitions of irreducible and prime for integral domains. (I have some issues/problems with the definitions - see below)
------------------------------------------------------------------------------------------------------------------------------- "Definition:
Let R be an integral domain.
(1) Suppose \(\displaystyle r \in R \) is non-zero and not a unit. Then r is called irreducible in R if whenever r = ab with [TEX] a, b \in R [/TEX] at least one of a or b must be a unit in R. Otherwise r is said to be reducible.
(2) The non-zero element [TEX] p \in R [/TEX] is called prime in R if the ideal (p) generated by p is a prime ideal. In other words, a non-zero element p is a prime if it is not a unit and whenever p|ab for any [TEX] a,b \in R [/TEX], then either p|a or p|b."
So where a ring of polynomials is an integral domain we have a definition of prime and irreducible elements (polynomials).
However, most algebra books I have referenced just talk about irreducible polynomials - and indeed define them in ways that look like D&F's definition of a prime element in an integral domain - so maybe for polynomials (for some reason?) irreducible and prime are the same thing? Can someone clarify this point?
Indeed, in the book Elements of Modern Algebra by Gilbert and Gilbert we find the following definition of an irreducible polynomial:
"A polynomial f(x) in F[x] is irreducible (or prime) over F (a field?) if f(x) has positive degree and f(x) cannot be expressed as a product f(x) = g(x)h(x) with both g(x) and h(x) of positive degree in F[x]."
Gilbert and Gilbert then follow this with the following theorem: (which seems to follow D&F definition of a prime in an integral domain - also - why is G&G using field and not an integral domain?)
"If p(x) is an irreducible polynomial over the field F and p(x) divides f(x)g(x), then either p(x) | f(x) or p(x) | g(x) in F[x] How does G&G's definition square with D&F's definitions. Can someone please clarify?
Another point is that I am unsure why D&F restrict these definitions to an integral domain thus leaving the terms undefined for general rings that are not integral domains. Can someone clarify?
Yet another problem I have with the above definitions by D&F is the following: D&F write: "In other words, a non-zero element p is a prime if it is not a unit and whenever p|ab for any [TEX] a,b \in R [/TEX], then either p|a or p|b." - How does this follow from (p) being a prime ideal.
Peter Note: D&F's definition of prime ideal is on page 255 and is as follows: Definition: Assume R is commutative. An ideal P is called a prime ideal if [TEX] P \ne R [/TEX] and whenever the product of two elements [TEX] a,b \in R [/TEX] is an element of P, then at least on of a and b is an element of P.
