MHB Prime Subfiellds - Lovett, Proposition 7.1.3 ....
  • Thread starter Thread starter Math Amateur
    Prime
The discussion centers on Proposition 7.1.3 from "Abstract Algebra: Structures and Applications" by Stephen Lovett, specifically regarding the structure of the subfield $$\mathbb{F}_p = \mathbb{Z} / p \mathbb{Z}$$. Participants clarify that for a prime p, this set includes elements {0, 1, 2, ..., p-1} and possesses multiplicative inverses for all nonzero elements. The confusion arises from understanding how elements like $$1/2$$ and $$3/5$$ are defined within this structure. Suggestions are made to revisit earlier discussions on finite fields for better comprehension. Overall, the conversation emphasizes the importance of grasping the properties of finite fields in relation to the proposition.
Math Amateur
MHB
I am reading Abstract Algebra: Structures and Applications" by Stephen Lovett ...
I am currently focused on Chapter 7: Field Extensions ... ...
I need help with the proof of, or at least some remarks concerning, Proposition 7.1.3 ...Proposition 7.1.3 plus some introductory remarks (proof?) reads as follows:
https://www.physicsforums.com/attachments/6543
In the above text from Lovett we read the following:"... ... However, the multiplication on these elements as defined by distributivity gives this set of elements the structure of $$\mathbb{F}_p = \mathbb{Z} / p \mathbb{Z}$$. ... ... " ... ... BUT ... the subfield contains elements $$0, 1, 2, 3, 4, 5, \ ... \ ... \ (p -1)$$ ... and being a field, it contains divisions of these elements such as $$1/2, 3/5 \ ... \ ... \ ...$$... so how can this subfield be equal to $$\mathbb{Z} / p \mathbb{Z}$$ ... ... ?
Hope someone can help ...
Peter
Are you aware that $\mathbb{Z} / p \mathbb{Z}$ is a field for a prime $p$ and therefore contains multiplicative inverses of all nonzero elements?
Thanks Evgeny ... hmmm ... certainly seems that Lovett assumed I was aware of that ... ...
I was dimly aware ... but uncertain of how and why it all worked out ...
Intend to read material on finite fields in some of my texts ...
Peter
Hi Peter,
I would suggest looking back at your earlier posts on finite fields, in particular, one of your featured posts on finite fields.
For example, if p= 5 them F_p has the set {0, 1, 2, 3, 4} with "multiplication" being "multiplication modulo 5". In particular, 2*3= 6= 1 (mod 5) so "1/2" is "3" and "1/3" is "2". 4*4= 16= 1 (mod 5) so 4 is its own multiplicative inverse: "1/4" is "4".
Euge said:
Hi Peter,
Yes ... good suggestion Euge ...
On my excursion into finite fields, I obviously did not spend enough time and effort on the topic ...
Peter
- - - Updated - - -
Thanks HallsofIvy ... your post was most helpful ...
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
