MHB Principal Ideals and Bezout Domains - (a,b)
  • Thread starter Thread starter Math Amateur
    domains
Math Amateur
MHB
Just a further (very basic!) question:
Is the following argument - working from definitions - correct
Does (a) + (b) = (a,b)?
By definition (Dummit and Foote page 251) (a, b) = \{r_1a + r_2b \ | \ r_1, r_2 \in R \}
[Note (a, B) includes the terms r_1a and r_2b since r_1 or r_2 can equal 0.]
Also by definition we have (a) = \{r_1a \ | \ r_1 \in R \} and (b) = \{r_2b \ | \ r_2 \in R \}
Now if by '+' we mean the "addition" (union or putting together) of sets then we have
(a) + (b) = \{r_1a, r_2b \ | \ r_1, r_2 \in R \}
so we are missing the 'addition' terms r_1a + r_2b of (a, B). But if we take (as we probably should) the '+' to mean the sum of ideals - then the definition is (Dummit and Foote page 247) for ideals X and Y in R
X + Y = \{x + y \ | \ x \in X, y \in Y \}
Working, then, with this definition we have
(a) + (b) = \{ r_1a + r_2b \ | \ r_1, r_2 \in R \} and this is the same as the definition of (a, b) so (a) + (b) = (a, b) from the definitions.
Is this correct?
If the above is correct then seemingly for an ideal generated by the set A = \{ a_1, a_2, ... ... a_n \} we have that
(a_1, a_2, ... ... a_n) = (a_1) + (a_2) + ... ... (a_n)
Is this correct?
Just another vaguely connected question.
Given a ring R consisting of the elements \{a_1, a_2, ... ... a_n \}
do there always (necessarily?) exist ideals A_1 = (a_1) , A_2 = (a_2), ... ... A_n = (a_n)
Help with confirming (or otherwise) my reasoning & clarifying the above issues would be much appreciated.
Note that if you agree with my reasoning above then a brief confirmation would be very helpful.
Peter
[Also posted on MHF]
A lot to look at here, I'll try to break it down and hope I don't miss anything.
By definition (Dummit and Foote page 251) (a,b)={r1a+r2b | r1,r2∈R}
[Note (a, B) includes the terms r1a and r2b since r1 or r2 can equal 0.]
Also by definition we have (a)={r1a | r1∈R} and (b)={r2b | r2∈R}
(a)+(b)={r1a,r2b | r1,r2∈R}
so we are missing the 'addition' terms r1a+r2b of (a, B).But if we take (as we probably should) the '+' to mean the sum of ideals - then the definition is (Dummit and Foote page 247) for ideals X and Y in R
X+Y={x+y | x∈X,y∈Y}
(a)+(b)={r1a+r2b | r1,r2∈R} and this is the same as the definition of (a, b) so (a) + (b) = (a, b) from the definitions.
I have no idea what you mean by this bit:
But outside of that, your reasoning seems correct here. I guess that means that your second definition of set addition is the correct one. I assume that our discussion is limited then to commutative rings; otherwise, you would have to extend the definition of the ideal to include right-multiplication.
You can proceed to extend that definition (for finitely many elements) by induction, using the fact that the sum of any two ideals is an ideal.
Any element in a ring can be used to generate an ideal, but that ideal need not be proper. In fact, I'm fairly sure that the ideal generated by a will be R itself (not proper) iff a has a multiplicative inverse in R.
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
