Principal value of complex number
In summary: Therefore, the principal value of (\sqrt{3}+i)^{1/6} is \sqrt[6]{2}\exp \left( {\frac{\pi }{{36}}} \right) or \eta when k = 0. In summary, the principal value of (\sqrt{3}+i)^{1/6} is \sqrt[6]{2}\exp \left( {\frac{\pi }{{36}}} \right) or \eta when k = 0, and all six values are evenly spaced around a circle with a magnitude of \sqrt[6]{2}.
Suvadip
74
Find all the values of \(\displaystyle (\sqrt{3}+i)^{1/6}\). What is its principle value?I have doubt about the second part. We have heard about the principal value of the amplitude of a complex number. But here the principal value of the complex number itself is asked for. Please help
Mathematics news on Phys.org
Re: principal value of complex number
\(\displaystyle \eta = \sqrt[6]{2}\exp \left( {\frac{\pi }{{36}}} \right)\) is one sixth root of \(\displaystyle \sqrt{3}+i\).
If \(\displaystyle \zeta =\exp \left( {\frac{\pi }{{3}}} \right)\) then \(\displaystyle \eta\cdot\zeta^k,~k=0,1,\cdots 5\) are all six.
I have seen \(\displaystyle \eta\) (i.e. \(\displaystyle k=0\)) called the principal root.
It helps if you remember that there are always two square roots, three cube roots, four fourth roots, etc, and they are all evenly spaced around a circle. So in this case, if you can evaluate one value, the rest will all have the same magnitude and be separated by an angle of \(\displaystyle \displaystyle \frac{2\pi}{6} = \frac{\pi}{3} \).
FAQ: Principal value of complex number
What is the principal value of a complex number?
The principal value of a complex number is the unique value of the argument that lies within the range of -π to π. It is denoted by the symbol Arg(z).
How is the principal value of a complex number calculated?
The principal value of a complex number is calculated by finding the angle between the positive real axis and the line joining the origin to the complex number in the complex plane.
Why is the principal value of a complex number important?
The principal value of a complex number is important because it is used to define the polar form of a complex number, which is crucial in many mathematical and engineering applications.
What is the difference between principal value and principal argument?
The principal value is the unique value of the argument that lies within the range of -π to π, while the principal argument is the argument expressed in radians between -π and π.
Can the principal value of a complex number be negative?
Yes, the principal value of a complex number can be negative if the complex number is in the second or third quadrant of the complex plane, where the argument is greater than π or less than -π.
