Principle Ideal in F[x] & Primitive nth root of unity
In summary: Read moreIn summary, the conversation discusses finding a monic polynomial of degree two in the field extension K(ζ + ζ−1), where ζ is defined as e2πi/5. The conversation mentions that the polynomial should have a root of ζ + ζ−1 and the coefficient of x^2 should be 1. It also discusses the use of automorphisms and Galois groups to find the fixed field of the subgroup of the Galois group of order 2, which turns out to be the field K(ζ + ζ−1) itself.
mathjam0990
29
Let ζ5 be e2πi/5. Find a monic polynomial of degree two in K(ζ + ζ−1)
So, if E/F is a field extension, with α∈E then K(α) = {f(x)∈F[x] | f(α)=0} and m(x) is the minimal polynomial of α over F such that K(α) = [m(x)] where [m(x)] is the ideal generated by m(x).
I was thinking maybe (x- ζ - ζ−1)(x + ζ - ζ−1). Sorry I am not sure how to approach this exactly but I know of course ζ + ζ−1 should be a root of this degree 2 polynomial with the x2 coefficient as 1.
If anyone could provide an explanation that would be very helpful. Thank you.
I hope you meant "irreducible monic polynomial", as there are several monic polynomials that are possible (take any monic quadratic from $\Bbb Q[x]$, for example).
You also don't say what "$K$" is, which is important. There are lots and lots of fields, and reducibility depends in an essential way on "which field we're in".
I will pretend $K = \Bbb Q$, the rational numbers.
First, some preliminary facts about $\zeta = e^{\frac{2\pi i}{5}}$:
Note that $\zeta^5 = 1$ which implies $\zeta^{-1} = \zeta^4$.
From $\zeta^5 = 1$ it is evident that $(\zeta^k)^5 = \zeta^{5k} = (\zeta^5)^k = 1^k = 1$. It is easy to see that:
$\zeta,\zeta^2,\zeta^3,\zeta^4$ are all distinct (use trigonometry) and thus that:
$1,\zeta,\zeta^2,\zeta^3,\zeta^4$ are 5 distinct roots of $x^5 - 1$, and thus that $\Bbb Q(\zeta)$ is the splitting field of:
$\dfrac{x^5 - 1}{x - 1} = x^4 + x^3 + x^2 + x + 1$.
The RHS is the 5th cyclotomic polynomial, and these are all irreducible over $\Bbb Q$. This is a non-trivial theorem, but the proof for the $p$-th cyclotomic polynomial (for a prime $p$) is somewhat easier. I will not prove this here, we can discuss it later, if you like.
So, evidently:
$x^4 + x ^3 + x^2 + x + 1 = (x - \zeta)(x - \zeta^2)(x - \zeta^3)(x - \zeta^4)$.
Thus this polynomial ($\Phi_5(x)$) is separable, and since adjoining one root gives us the entire splitting field, it is a Galois extension of $\Bbb Q$ (it is separable, and normal). So the Galois group is the same as $\text{Aut}(\Bbb Q(\zeta)/\Bbb Q)$, and has order 4.
Since $\sigma:\Bbb Q(\zeta) \to \Bbb Q(\zeta)$ defined by $\sigma(\zeta) = \zeta^2$ is an element of this group, and has order 4:
$\sigma^2(\zeta) = \sigma(\sigma(\zeta)) = \sigma(\zeta^2) = (\sigma(\zeta))^2 = \zeta^4$
$\sigma^3(\zeta) = \sigma(\sigma^2(\zeta)) = \sigma(\zeta^4) = (\sigma(\zeta))^4 = \zeta^8 = \zeta^3$
$\sigma^4(\zeta) = \sigma(\sigma^3(\zeta)) = \sigma(\zeta^3) = (\sigma(\zeta))^3 = \zeta^6 = \zeta$
we see this group is cyclic. By the Galois correspondence, we see that since we have just ONE subgroup of order 2 (namely: $\{\text{id},\sigma^2\}$), we have just one subfield of $\Bbb Q(\zeta)$ of dimension 2 over $\Bbb Q$ as a vector space. We will see shortly, that that field is $\Bbb Q(\zeta+\zeta^{-1})$.
Our automorphism group can be regarded as a permutation group acting on the roots of $x^4 + x^3 + x^2 + x + 1$, in this case, we have that:
$\sigma \mapsto (1\ 2\ 4\ 3)$
$\sigma^2 \mapsto (1\ 4)(2\ 3)$
$\sigma^3 \mapsto (1\ 3\ 4\ 2)$
$\sigma^4 \mapsto e$
So the subfield we are looking for is the field fixed by $\{\text{id}, \sigma^2\}$, which suggests grouping the polynomial factors like so:
$[(x - \zeta)(x - \zeta^4)][(x - \zeta^2)(x - \zeta^3)]$
Since each quadratic of the factorization above is fixed by $\sigma^2$ (it just swaps roots in each quadratic pair), the coefficients must lie in the fixed field of $\{\text{id}, \sigma^2\}$. In particular:
$(x - \zeta)(x - \zeta^4) = (x - \zeta)(x - \zeta^{-1}) = x^2 - (\zeta + \zeta^{-1})x + 1$
has coefficients in this fixed field. So the fixed field CONTAINS $\Bbb Q(\zeta + \zeta^{-1})$.
Note as well, that complex conjugation restricted to $\Bbb Q(\zeta)$ is an automorphism of $\Bbb Q(\zeta)$ of order 2 that fixes $\Bbb Q$, so $\sigma^2$ IS complex conjugation.
What that tells us, is that $\zeta^4 = \overline{\zeta}$, and thus that $\Bbb Q(\zeta+\zeta^{-1}) \subseteq \Bbb R$.
Since the roots of $x^2 - (\zeta + \zeta^{-1})x + 1 = (x - \zeta)(x - \overline{\zeta})$ are not real, they certainly do not lie in $\Bbb Q(\zeta+\zeta^{-1})$, and thus:
$x^2 - (\zeta + \zeta^{-1})x + 1$ is irreducible over $\Bbb Q(\zeta + \zeta^{-1})$, which is presumably what you were looking for.
As promised, we will now show the fixed field of the unique subgroup of the Galois group of order 2 IS $\Bbb Q(\zeta + \zeta^{-1})$ (we already know it contains it).
To this end, some preliminary algebra:
$(\zeta + \zeta^{-1})^2 = \zeta^2 + 2(\zeta\zeta^{-1}) + (\zeta^{-1})^2 = \zeta^2 + 2 + \zeta^{-2} = \zeta^2 + \zeta^3 + 2$.
Now the elements of $\Bbb Q(\zeta)$ are of the form:
$a_0 + a_1\zeta + a_2\zeta^2 + a_3\zeta^3: a_0,a_1,a_2,a_3 \in \Bbb Q$.
If such an element $u$ is fixed by $\sigma^2$ (that is $\sigma^2(u) = u$), then we have:
$a_0 + a_1\zeta + a_2\zeta^2 + a_3\zeta^3 = \sigma^2(a_0 + a_1\zeta + a_2\zeta^2 + a_3\zeta^3)$
$= a_0 + a_1\sigma^2(\zeta) + a_2\sigma^2(\zeta^2) + a_3\sigma^2(\zeta^3)$
$= a_0 + a_1\zeta^4 + a_2\zeta^3 + a_3\zeta^2$.
Recall that $\zeta^4 + \zeta^3 + \zeta^2 + \zeta + 1 = 0$, so:
$\zeta^4 = -\zeta^3 - \zeta^2 - \zeta - 1$, so that:
$a_0 + a_1\zeta^4 + a_2\zeta^3 + a_3\zeta^2 = (a_0 - a_1) - a_1\zeta + (a_3 - a_1)\zeta^2 + (a_2 - a_1)\zeta^3$.
Equating the coefficients (they must be equal, since by the linear independence of $\{1,\zeta,\zeta^2,\zeta^3\}$ over $\Bbb Q$ these coefficients are unique), we have:
$a_0 = a_0 - a_1$
$a_1 = -a_1$
$a_2 = a_3 - a_1$
$a_3 = a_2 - a_1$, so that $a_1 = 0$, and $a_2 = a_3$.
Thus the elements fixed by $\sigma^2$ are of the form:
$a_0 + a_2\zeta^2 + a_2\zeta^3 = a_0 + a_2(\zeta^2 + \zeta^3) = a_0 - 2a_2 + a_2(\zeta^2 + \zeta^3 + 2)$
$= a_0 - 2a_2 + a_2(\zeta + \zeta^{-1})^2 \in \Bbb Q(\zeta + \zeta^{-1})$
and we see the fixed field is contained in $\Bbb Q(\zeta + \zeta^{-1})$, and thus the two are equal.
Perhaps you were only looking for the "grouping" of factors I did earlier-this is rather the scenic route, and there are shorter ways to get from point A to point B, but I believe it helps to see how the information we get from group theory "forces our hand" in discussing the field structure (which would otherwise be "harder to arrive at").
Thank you very much. This was helpful!
FAQ: Principle Ideal in F[x] & Primitive nth root of unity
What is the principle ideal in F[x]?
The principle ideal in F[x] is an ideal generated by a single element in the polynomial ring F[x]. It is denoted as (f) where f is a non-zero polynomial in F[x]. It contains all the multiples of f along with 0.
How is the principle ideal related to the primitive nth root of unity?
The principle ideal (x^n - 1) in F[x] is closely related to the primitive nth root of unity. This is because the polynomial x^n - 1 has all the nth roots of unity as its roots. Therefore, the principle ideal (x^n - 1) contains all multiples of the primitive nth root of unity.
What is the significance of the primitive nth root of unity in principle ideal?
The primitive nth root of unity plays a significant role in the principle ideal (x^n - 1) because it generates all the other nth roots of unity. This means that any multiple of the primitive nth root of unity will also be a root of the polynomial x^n - 1, and hence, will be contained in the principle ideal.
How does the principle ideal help in solving polynomial equations?
The principle ideal (f) in F[x] can be used to solve polynomial equations by factoring out the polynomial f. This allows us to find the roots of the given polynomial equation and thus, solve it. The primitive nth root of unity can also be used in this process as it is a root of the polynomial x^n - 1.
Can the principle ideal (x^n - 1) be used for any value of n?
Yes, the principle ideal (x^n - 1) can be used for any value of n. This is because the polynomial x^n - 1 has roots for all positive integers n, and therefore, the principle ideal (x^n - 1) will contain all the multiples of the primitive nth root of unity for any value of n.
