Queren Suriano
- 50
In the gear arrangement shown, gears A and C are attached to rod ABC,
which is free to rotate about B, while the inner gear B is fixed. Knowing
that the system is at rest, determine the magnitude of the couple M which
must be applied to rod ABC, if 2.5 s later the angular velocity of the rod is
to be 240 rpm clockwise. Gears A and C weigh 2.5 lb each and may be
considered as disks of radius 2 in.; rod ABC weighs 4 lb
Syst. Momenta 1 + Syst. Ext. Imp. 1→2 = Syst. Momenta
: I draw external drives like this.[/B]However in Figure 2 corresponds to the solution of the problem, they draw only two forces: P and Q , but I don't really understand how they simplify all other forces in only one force Q (weight and reactions on the pin to get to that)
