Printing 1D array in Fortran as 2D array
In summary, the conversation is about deleting a post and using a semi-colon as an implicit "all" when operating on arrays. The participants also discuss the difference between a colon and a semi-colon and the importance of not deleting posts as they may be helpful to others.
BC2210
Delete..
Delete..
Technology news on Phys.org
They're not crazy, if I want to print all row entries in a column, then:
Code:
REAL,DIMENSION(2,3) :: array
DO,i=1,2
  WRITE(6,*) array(i,:)
END DO
You can use the semi-colon as an implicit "all" when operating on arrays.
Yes. In C, two-dimensional arrays are simply one-dimensional arrayswhose element type is itself a one dimensional array. Since one-dimensional arrays are required to occupy contiguous storage, itfollows that the same must be true for an array of arrays.
Thanks
__________
Techstore are specialists in a range of http://www.techstore.ie/Design-Print/index.html" Services
Code:
DO,i=1,2
END DO
I don't think you want that first comma after the DO.
This character - : - is a colon. This one - ; - is a semicolon.
Right-o, as far as the comma, I occasionally get f90 and ANSYS APDL mixed up a bit. Also can't believe I called a, ':', a semi-colon. 1:11pm, perhaps, I was in a lunch daze.
BC2210 said:
Delete..
BC2210,
Although it's possible for you to delete your own post, it's not a good idea to do so. Other people can possibly learn from your question.
but why you want to delete the post was it not relevant
may be it was
Related to Printing 1D array in Fortran as 2D array
1. How can I print a 1D array in Fortran as a 2D array?
To print a 1D array in Fortran as a 2D array, you can use a DO loop to iterate through the array and print each element in the desired format. You can also use the RESHAPE function to convert the 1D array into a 2D array before printing.
2. What is the purpose of printing a 1D array as a 2D array in Fortran?
The purpose of printing a 1D array as a 2D array in Fortran is to visualize the data in a more organized and structured format. This can be helpful in understanding the data and identifying any patterns or trends.
3. Can I specify the number of columns when printing a 1D array as a 2D array in Fortran?
Yes, you can specify the number of columns when printing a 1D array as a 2D array in Fortran using the RESHAPE function. This allows you to control the layout of the printed array and make it easier to read.
4. Is it possible to print a 1D array as a 2D array in Fortran without using a DO loop?
Yes, it is possible to print a 1D array as a 2D array in Fortran without using a DO loop by using the RESHAPE function. This function allows you to reshape the array without having to iterate through each element.
5. Can I print a 1D array as a 2D array in Fortran with non-numeric data?
Yes, you can print a 1D array as a 2D array in Fortran with non-numeric data. However, the RESHAPE function may not work for non-numeric data. In this case, you can use a DO loop to iterate through the array and print each element in the desired format.
