Probabality of jumping of e in K-e capture.
  • Thread starter astro2cosmos
  • Tags
    Capture
In summary: The 2s-1s and 3s-1s transitions are forbidden. Both the 2p-1s and 3p-1s transitions are partially screened by other electrons.
astro2cosmos
71
as we know in L orbit there are two shell 2s & 2p. suppuse for an atom both shells are occupied , then what is the probabality of jumping of any electron from 2s & 2p shell to lower 1s in the process of K-electron capture process?
Let's examine Ar=37 that decays only by electron capture.
The electron configuration in Ar-37 prior to decay is 1s(2) 2s(2) 2p(6) 3s(2) 3p(6) for a total of 18 electrons (where the number in parenthesis the number of electrons in each state). When a 1s electron is captured by the nucleus, electrons in both the 2p and the 3p states compete for the vacancy in the 1s state.
I don't have the exact answer, but for the single-electron hydrogen atom, the 2p-1s and 3p-1s transition rates are 6.25 x 108 and 1.64 x 108 sec-1 respectively*. implying that the 2p-1s transition is much more likely than the 3p-1s transition. Measuring the K x-ray fine structure maybe can determine the ratio.
From page 266 in Bethe and Salpeter Quantum Mechanics of One and Two Electron Atoms.
Bob S
Bob S
ok. so does 2s or 3s also try to fill up the vacany?
during the transition from 2p & 3p screening effect is also apply?
from which i.e 2s or 2p it is readily jump to 1s?
Bob S
Related to Probabality of jumping of e in K-e capture.
1. What is K-e capture?
K-e capture is a type of nuclear decay process where an electron from the innermost energy level (K-shell) of an atom is absorbed by the nucleus, resulting in the emission of a neutrino and the conversion of a proton into a neutron.
2. What is the probability of e jumping during K-e capture?
The probability of an electron "jumping" during K-e capture is determined by the electron's wave function, which describes the likelihood of finding the electron at a given location. This probability is dependent on the energy level of the electron and the strength of the nuclear force.
3. How is the probability of e jumping calculated in K-e capture?
The probability of e jumping during K-e capture is calculated using quantum mechanical models, specifically the Fermi's Golden Rule, which takes into account the energy levels and wave functions of the electron and the nucleus. Other factors such as the nuclear structure and the strength of the weak interaction also play a role in the calculation.
4. What factors affect the probability of e jumping in K-e capture?
The probability of e jumping in K-e capture is influenced by the energy level of the electron, the strength of the nuclear force, and the nuclear structure of the atom. Additionally, the probability can also be affected by the presence of other particles, such as neutrinos and electrons, which can interact with the electron and alter its behavior.
5. Is the probability of e jumping in K-e capture always the same?
No, the probability of e jumping in K-e capture can vary depending on the specific atom and its nuclear structure. Additionally, the probability can also change with different experimental conditions, such as the energy of the electron or the strength of the nuclear force.
