Probabilistic particle-scale valve with no moving parts
In summary: Additionally, the walls of the hole would need to be very smooth in order to minimize diffusion of gas molecules. Finally, the gas would need to be at equilibrium with the walls of the hole, and the device would need to operate continuously. In summary, this is not a feasible proposal.
Filip Kierzek
Hi,
Smoluchowski's trap door was proven to fail to obtaining work in a system without heat difference. The problem turns is random movement of trap door due to random particle movements. However I could not find any discussions of such system where the "trap door" did not involve moving parts. I am wandering if it would be possible to construct a specially shaped hole (with no moving parts) in a wall separating two chambers of gas filled box, such that the whole would have a higher likelihood of allowing gas molecules to pass from one way than the other and not involve any moving parts. Intuition suggests that one could shape the hole in such a way so that molecules would be more likely to bounce away / towards the hole e. g. one side being convex and the other side concave.
However existence of such hole should be impossible as it would lead to violation of second law of thermodynamics and extraction of work from system with single heat reservoir. I would appreciate if someone would be kind enough to pinpoint the flaw the above reasoning.
thank you
Filip
Molecular sieves, zeolites, custom fullerene tubes, all with atomic and molecular scale pores? Oh, the possibilities for molecular "wasp traps!" "Not." Unfortunately (probably good fortune for all of us in terms of being the way the universe works) there does not appear to be any such thing as a nice clean "single bank off the side cushion" billiard shot collision of vapor molecules with "solid" surfaces. It's "hit and stick" on clean surfaces (which have only been prepared by cleaving in high vacuum); once a surface is in equilibrium with the vapor phase surrounding it, surface sites and adsorbed gas molecules play "hot potato" with the kinetic energy of the molecule colliding with the surface and eject another, previously adsorbed molecule from an adjacent or nearby site with the same (sometimes more, sometimes less) energy (Boltzmann runs that roulette wheel) according to the cosine(?) law for scattering.
A non-sticky cast neutronium wasp trap? Wasp and minnow traps depend not on the ratio of the sizes of ends of conic sections, but on the asymmetry and tropisms of the animals being trapped. Molecules in field free space are not going to be traveling with specific orientations necessary to make such a trap work.
No. Such a hole will do work on the gas without an energy source, so you have gone from violating the 2nd law of thermodynamics to violating the 1st.
Interestingly, there are some specific cases when gas molecules do bounce off surfaces in a method more akin to a billiard ball rather than the stick and scatter you mention here. It's not common, but in a fairly high vacuum with a correctly prepared surface, specular (rather than diffuse) reflection is possible. Of course, for this to happen, the surface must be incredibly clean, the molecular weight of the gas must be much smaller than the molecular weight of the surface material, and the gas molecules must be moving quickly (usually several km/s).
That had me digging in the library for days when I was getting up to speed on spinning rotor gauges.
Filip, as I told you previously, we do not discuss perpetual motion machines here on PF, not even to debunk them.
Regarding your specific PMM proposal, even if you could set up the ideal perfect "beveled hole" you would need to analyze not only the size of the holes, but also the angle of incidence on the wall of the hole.
Related to Probabilistic particle-scale valve with no moving parts
What is a probabilistic particle-scale valve with no moving parts?
A probabilistic particle-scale valve with no moving parts is a type of valve that uses a probabilistic mechanism to control the flow of particles without the need for any physical moving parts. It is based on the principles of quantum mechanics and can be used in various applications, such as microfluidics and nanotechnology.
How does a probabilistic particle-scale valve work?
A probabilistic particle-scale valve works by using a probabilistic mechanism, such as a quantum tunneling effect, to control the flow of particles. This mechanism allows for precise and efficient control of the valve without the need for any physical moving parts.
What are the benefits of using a probabilistic particle-scale valve?
There are several benefits to using a probabilistic particle-scale valve, including its precise control over the flow of particles, its low energy consumption, and its compact size. It can also be used in harsh environments and has a longer lifespan compared to traditional valves.
What applications can a probabilistic particle-scale valve be used in?
A probabilistic particle-scale valve can be used in various applications, such as microfluidics, nanotechnology, and biomedical devices. It can also be used in industries that require precise control over the flow of particles, such as pharmaceuticals, chemicals, and food processing.
Are there any limitations to using a probabilistic particle-scale valve?
While a probabilistic particle-scale valve has many benefits, it also has some limitations. It may not be suitable for high-pressure and high-temperature applications, and its performance may be affected by external electromagnetic fields. Additionally, it may be more complex and expensive to manufacture compared to traditional valves.
