Probabilities Associated with Sudden Changes in Potential
In summary, when calculating probabilities for a sudden change in potential, such as in the case of a tritium atom undergoing spontaneous beta decay, we can use the inner product of the wave-functions for the ground states in the initial and final potentials to determine the probability of the electron being left in the ground state of the new potential. This is done because the wave-function does not have time to fully react to the sudden change in potential, so the probability is a measure of how much of the proposed state is present in the initial state. However, near the nucleus, the "sudden change" approximation may break down, leading to minor corrections.
CDL
Hi, I have a question about calculating probabilities in situations where a particle experiences a sudden change in potential, in the case where both potentials are time independent.
For example, a tritium atom undergoing spontaneous beta decay, and turning into a Helium-3 ion. The orbital electron is initially in the ground state. The main point about this example is that the orbital electron essentially experiences a sudden change in Coulomb potential, with atomic number Z = 1 to Z = 2. Suppose we want to calculate the probability that after this beta decay the electron is left in the ground state of the new potential. In order to do this, we just take the inner product of the wave-function for the ground state state with Z = 1 with the 1s state, Z = 2, and take the modulus squared. There is our probability. Something like $$\mathbb{P}(\text{1s initial to 1s final}) = |\langle \psi_{1sf} | \psi_{1si} \rangle|^2$$ Where ## \psi_{1si}## and ##\psi_{1sf}## are the wave functions of the ground states in the initial and final potentials.
From what I have seen, this is what is generally done in these situations where the potential suddenly changes, but I'm not entirely comfortable with why this is done. Is this just another way of writing $$\mathbb{P}(\text{transition from state a to state b}) = |\langle \psi_{b} | \psi_{a} \rangle|^2$$
Could someone please explain why this is done, and why we can do this even though the potential changes?
Is it the fact that the wave-function doesn't have time to react to such a change in potential, and so the probability is a measure of 'how much of the proposed state b is present in the state a' ?
Yes, this is the line of argument. Of course, this can't be entirely true for the whole wavefunction, as the change of the potential very near the nucleus is nearly infinite, so even if the decay occurs on a very short timescale somewhere very near the nucleus the "sudden change" approximation breaks down. But this will only lead to minor corrections.
Likes CDL
Related to Probabilities Associated with Sudden Changes in Potential
1. What is the definition of "Probabilities Associated with Sudden Changes in Potential"?
Probabilities Associated with Sudden Changes in Potential refer to the likelihood or chance of a sudden and significant shift in a system's potential, resulting in a change in the system's behavior or outcome.
2. How are these probabilities calculated?
These probabilities are typically calculated using mathematical models and statistical analyses based on data collected from past occurrences of sudden changes in potential. The specific method of calculation may vary depending on the system being studied and the available data.
3. What factors can influence these probabilities?
There are several factors that can influence the probabilities associated with sudden changes in potential. These may include the stability of the system, external forces or events, and the complexity of the system. Other factors may also include the accuracy and completeness of the data used for calculations and the assumptions made in the modeling process.
4. Can these probabilities be predicted accurately?
While scientific models and statistical analyses can provide estimates of probabilities associated with sudden changes in potential, it is important to note that these are only predictions and may not always be accurate. Factors such as unexpected events or incomplete data can impact the accuracy of these predictions.
5. How can understanding these probabilities be useful in scientific research?
Understanding probabilities associated with sudden changes in potential can be useful in various fields of scientific research, such as climate science, economics, and engineering. It can help identify potential risks and inform decision-making processes. Additionally, studying these probabilities can also lead to a better understanding of the underlying mechanisms and patterns of sudden changes in various systems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
