Probability and normal distribution
In summary: I'll let you think about it.In summary, the conversation discusses the contamination of apples grown near an industrial area and the potential for heavy metal contamination. The apples are believed to follow a normal distribution and are considered "acceptable" if they have less than 18 units of heavy metals. The conversation also explores the probability of randomly selecting an acceptable apple, the probability of needing more than 2 tests to find an acceptable apple, and constructing a confidence interval for the mean amount of heavy metals in a sample of 100 apples.
ichabodgrant
49
Due to the pollution from the industry around an apple farm, the apples grown there may be contaminated by heavy metals. It is believed that the amount of heavy metals in an apple of the farm follows the Normal distribution.
N(16,16) which has a mean μ = 16 units and σ = √16 = 4 units. An apple is said to be "acceptable" if the amount of heavy metals is less than 18 units.
First, what is the probability that a randomly selected apple is acceptable?
Second, if each apple is taken to be conducted in a test of heavy metals content (assuming each test is absolutely accurate), what is the probability that more than 2 tests are required for obtaining the first acceptable apple.
Third, now the pollution is getting worse and an investigation is conducted by randomly selecting 100 apples. The average amount of heavy metals is 20 units. We assume that the s.d. remains the same as the question says. Construct a 95% confidence interval for the mean amount of heavy metals μ.
P(X <=-k) = P(X>=k)
The normal distribution pdf
Z = (X - μ)/σ
P( (barX - μ)/(σ/√n) <= Zα/2) = β, where confidence level β = 1 - α
Let X be the random variable meaning the amount of heavy metals found in an apple.
For the first question, I try to calculate P(X<=18). By converting it to standard normal distribution using
Z = (X - μ)/σ. But I have a question on whether I should calculate P(X<18). If so, does it mean I have to minus P(X=18) from P(X<=18)? Or are they the same? Or I should us the continuity correction factor?
For the second question, I have thought about calculating that P(more than 2 tests) = 1 - P(1 test) - P(2 tests).
Does it mean that I use the prob. I got in part a i: P(1st rejected) = 1 - P(1st acceptable) = 1 - P?
For the third question, I just plug in the formula P( (barX - μ)/(σ/√n) <= Zα/2) = β to find the intervals?
P(X <=-k) = P(X>=k)
Z = (X - μ)/σ
(1) For a continuous random variable, like your X, the probability of getting any particular exact value is 0, so P(X = 18) = 0. There is no difference between P(X < 18) and P(X <= 18). There is no reason why the metal content X must come in discrete chunks; presumably, X can be any real value >= 0.
The "continuity correction factor" you ask about is used when approximating a discrete random variable (which might be difficult to work with in computations) by a continuous approximating random variable. So, for example, we might replace a binomial random variable N, taking values in {0,1,2,3,..., 100} by a normal approximation X with the same mean and variance as N. The normal X can take any real value, and the continuity correction would come into play when re-writing events like {N <= k} in terms of X.
(2) If the apples are independent, do you think that whether or not apple #1 passes the test will influence whether or not apple #2 passes or fails? What do you know about probabilities for independent events?
(3) Try it and see for yourself.
I understand 1st and 3rd question now.
For 2nd question,
my approach now is
let p be the P(accpetable) in 1st question.
P(more than 2 tests) = 1 - [ P(1st acceptable) + P(1st rejected, 2nd accpetable) ] = 1 - [ p + (1-p)p ]. Is this correct?
For the first question: You can not add things that do not have the same dimension. P(X=18) is a probability density (a height if you want to consider it in this context). In contrast P(X<=18) is a probability, a short form for $$ \int_{-\infty}^{18} P(x) dx $$ (an area in this context).
There is no difference between P(X<=18) and P(X<18), strange as it may seem. The difference between the two is an integral over a range with width zero.
For the second test you want to think of a different formula: if you continue tests your formula would end up with a negative probability !
[edit] slow typist
So is this P(more than 2 tests) = 1 - [ P(1st acceptable) + P(1st rejected, 2nd accpetable) ] = 1 - [ p + (1-p)p ] wrong?
Makes me think of "what is the probability there is no 6 when you throw 6 dice" . Lots of folks go 1/6 + 1/6 + 1/6 + 1/6 + 1/6 + 1/6 = 1 so the answer is 0.
You want it a lot simpler: P = P(1st rejected and 2nd rejected)
because question 1 is P(acceptable)...so I use it directly...
So P(unacceptable) = 1 - P(acceptable). To make it necessary to grab more than 2 apples you square that.
There is an implicit assumption here that there are a lot of apples to select from :smile:
And yes, ##(1-p)^2 \ne 1-p^2##
P(reject) = 1 - P(accept), so you can use whichever is more convenient. Once and for all, rid your mind of the thought that you must always work directly with what you are given initially. Sometimes, when you want information about acceptances it is easier to look instead of rejections and work with those. In probability especially, it is very common to compute a probability of an event by, instead, computing the probability of the complementary even, then subtracting that from 1.
Related to Probability and normal distribution
1. What is probability and how is it related to normal distribution?
Probability refers to the likelihood of a particular event occurring. Normal distribution, also known as Gaussian distribution, is a statistical concept that describes the distribution of data in a bell-shaped curve. The area under the curve represents the probability of a certain range of values occurring, making it useful for predicting outcomes and analyzing data.
2. How is normal distribution calculated and represented?
Normal distribution is calculated using the mean and standard deviation of a set of data. The curve is symmetrical, with the mean at the center and the standard deviation determining the spread of the data. It is represented graphically as a bell-shaped curve, with the x-axis showing the values and the y-axis showing the frequency or probability of those values occurring.
3. What is the importance of normal distribution in scientific research?
Normal distribution is important in scientific research because it allows scientists to make predictions and draw conclusions about a population based on a sample of data. It is also used to test hypotheses and determine the likelihood of an event occurring. In addition, many real-life phenomena, such as height and weight of individuals, tend to follow a normal distribution, making it a useful tool in understanding and analyzing data.
4. How does the central limit theorem relate to normal distribution?
The central limit theorem states that the sampling distribution of the mean of a large number of independent samples from a population will be approximately normally distributed, regardless of the underlying distribution of the population. This means that even if the population does not follow a normal distribution, the sample means will still be normally distributed, making normal distribution a powerful tool for statistical analysis.
5. Can normal distribution be used to make predictions?
Yes, normal distribution can be used to make predictions about the likelihood of a certain event occurring. By calculating the area under the curve within a certain range of values, we can determine the probability of that event occurring. This can be useful in various fields such as finance, economics, and engineering, where it is important to make accurate predictions based on data.
