MHB Probability calculation involving very large numbers
The discussion revolves around calculating probabilities involving a large sample size of 200 million individuals, focusing on specific probabilities related to 60,000 target individuals. The key calculations include determining the chances that none of the selected 10 million individuals are from the target group, that at least 40 are from the target group, and that all 60,000 are included in the sample. The probabilities for these scenarios are extremely small, with the chance of selecting no red marbles being less than 10^-1336, while the probability of selecting at least 40 red marbles is significantly high, greater than 1 - 40 * 10^-1246. The discussion also suggests using logarithmic calculations to manage the large numbers involved, as direct computation is impractical. This approach provides a clearer path to presenting the findings in a simplified manner for legal explanations.
Matt2
Hi, I'm trying to figure out how to compute probability related to a problem I am tackling for work, and I think I have a handle on how to do it with smaller numbers, but no idea how to approach it for larger numbers. (And I need to explain the answers to a judge in simple terms). So here is the problem:
Imagine a company that maintains data about 200,000,000 Americans. Each month, this company takes a completely random sample of 5% of these reports to analyze. However, we are concerned only with 60,000 specific people out of this group of 200,000,000.
So we can visualize this as 60,000 "red marbles" and 199,940,000 "white marbles". Assuming that these combined 200,000,000 marbles are placed into a very large container and that 10,000,000 are selected randomly. I am trying to calculate:
1) The chance that none of the 10,000,000 marbles will be red;
2) The chance that 40 or more of the 10,000,000 marbles will be red;
3) The chance that all of the possible 60,000 red marbles will be included in the 10,000,000 selected.
Of these, the answer to question #2 is the most important, followed by #1, then #3.
Does anyone have an idea on where to start? I thought maybe it would make it easier to simply remove 4 zeroes from each number so that we are working with 20,000 / 6 / 1,000 but it seems that this skews the results. Would appreciate a pointer in the right direction.
Thanks!
Matt
Mathematics news on Phys.org
Hi Matt! Welcome to MHB! :)
Suppose you pick 1 marble.
What is the chance that it won't be red?
What if you pick 2 marbles?
Or 10?
Or 10,000,000?
Or 10?
Or 10,000,000?
the chance of 1 marble being white is 199,940,000 / 200,000,000
the chance of the 2nd marble being white would seem to be 199,939,999 / 199,999,999.
No idea after that. I became a lawyer because I wasn't good at math. :) And have tried a couple online math tutors who have told me that the answer to my questions cannot be calculated given the size of the numbers. Appreciate any help!
Let's give those numbers a name.
Let's define $N=200,000,000$, $n=199,940,000$, and $k=10,000,000$.
So the chance of 1 marble being white is:
$$P(1\text{ white}) = \frac n N$$
For 2 marbles we get:
$$P(2\text{ white}) = \frac n N \frac{n-1}{N-1} = \frac {n(n-1)}{N(N-1)}$$
For $k$ marbles we get:
$$P(k\text{ white}) = \underbrace{\frac {n(n-1)...(n-k+1)}{N(N-1)...(N-k+1)}}_{k\text{ factors}}$$Alternatively, we can use the general formula:
$$P = \frac{\text{Number of favorable outcomes}}{\text{Total number of outcomes}}$$
The number of favorable outcomes is the number of ways we can choose $k$ white marbles from the $n$ white marbles.
This is $n \choose k$.
The total number of outcomes is the number of ways we can choose $k$ marbles marbles from the total of $N$ marbles.
This is $N \choose k$.
So:
$$P(k\text{ white}) = \frac{n \choose k}{N \choose k}$$
[snip]
The answers to your questions are
1) Effectively zero (less than 10^-1336)
2) Effectively one (more than 1 - 40 * 10^-1246)
3) Effectively zero (less than 10^-78136)
Let's start by assigning names to some of your numbers:
N = 200,000,000
K = 60,000
n = 10,000,000
Then if p(x) is the probability the sample of n marbles will contain exactly x red marbles, then
$$p(x) = \frac{\binom{K}{x} \binom{N-K}{n-x}}{\binom{N}{n}}$$
where $\binom{n}{m} = \frac{n!}{m! (n-m)}$ is the number of ways to choose m items out of n, also known as a "binomial coefficient". See Hypergeometric distribution - Wikipedia, the free encyclopedia.
The trouble is, as you have already pointed out, it's not practical to calculate p(x) in this form with numbers as large as you have given; so we must resort to some tricks. We will calculate the logarithm of p(x) instead of calculating p(x) directly. This will enable us to deal with much smaller numbers in the intermediate calculations, so they can be done, for example, in double precision floating point, or in Excel, which uses double precision. So the first trick is to take the logarithm to the base e = 2.71828 of the equation for p(x):
$$\ln(p(x)) = \ln\binom{K}{x} + \ln \binom{N-K}{n-x} - \ln\binom{N}{n}$$
The second trick is to use a mathematical function available in Excel for the evaluation of the logarithms of the binomial coefficients. We have
$$\ln \binom{j}{k} = \ln \left( \frac{j!}{k! \; (j-k)!} \right) = \ln(j!) - \ln(k!) - \ln((j-k)!)$$
so we need a convenient way to evaluate $\ln(t!)$ for large values of $t$. Fortunately, Excel provides a function GAMMALN, defined by $GAMMALN(t) = \ln( \Gamma (t))$, where $\Gamma(t)$ is the Gamma function. (See Gamma function - Wikipedia, the free encyclopedia.) Since $t! = \Gamma(t+1)$ for a positive integer $t$, we have $GAMMALN(t+1) = \ln(t!)$.
If we put this all together and evaluate ln(p(0)) in an Excel spreadsheet, we find $\ln(p(0)) = -3078.07$, so $$\log_{10}(p(0)) = \frac{\ln(p(0))}{\ln(10)} = -1336.79$$ This shows that $p(0) < 10^{-1336}$, the answer to your first question.
For question 2), note that the probability that the sample of n marbles will not contain at least 40 red marbles is
$$\sum_{x=0}^{39} p(x)$$
If we go through the same steps as above to evaluate $\log_{10}(p(x))$ for $x = 0, 1, 2, \dots , 39$, we find the largest number in the sequence is $\log_{10}(p(39)) = -1246.62$. This shows $p(x) < 10^{-1246}$ for $x = 0, 1, 2, \dots , 39$, so
$$\sum_{x=0}^{39} p(x) < 40 \cdot 10^{-1246}$$ Since this is the probability that the sample does not contain at least 40 red marbles, the probability that the sample does contain at least 40 red marbles is greater than $1 - 40 \cdot 10^{-1246}$.
For question 3), we use the same method to evaluate the logarithm of p(60,000), and we find $\log_{10}(p(60,000)) = -78136.22$, so $p(60,000) < 10 ^{-78136}$, which is a small number indeed.
There are other ways to approach the problem. For example, we could approximate the Hypergeometric distribution with a Normal distribution. But I don't know how to bound the error of the approximation, so that method might be less convincing in court.
[edit] I changed some of the variable names, because in some cases I had used the same name for two different purposes in the original post. I hope this version is less confusing.[/edit]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
