MHB Probability: Choosing From A Deck Of Cards
  • Thread starter Thread starter Belfina
    Cards Probability
The discussion focuses on calculating probabilities from a standard deck of 52 cards when drawing 10 random cards. For the probability of drawing 0 aces, the product of probabilities for each card being a non-ace is calculated. To find the probability of drawing a maximum of 3 aces, the probabilities for 0, 1, 2, and 3 aces are summed, considering the different arrangements for each case. The probability of drawing at least one ace and at least one face card is approached by calculating the complementary probabilities and applying the principle of inclusion-exclusion. The calculations emphasize reasoning through the probabilities rather than relying solely on formulas.
Belfina
Hey there! So the problem is like this:
We choose 10 random cards from a normal deck of cards(52 cards). What is the probability that we get:
a. 0 aces
b. maximum 3 aces
c. at least 1 ace and at least one face card
I'm unsure which formula I should use. I have thought that maybe the sample space is: 52!/10!(52-10)!..
But I still can't solve it
Mathematics news on Phys.org
First, what you give is not the "sample space". A sample space is not a number!
Second, rather than using a "formula" you should be able to reason it out.
For the first one, of the 52 cards in a deck, 4 are aces, 48 are not. When you draw the first card, the probability it is not an ace is 48/52. If it is not an ace there are 51 cards left, 4 aces, 47 not. The probability the second card is not an ace is 47/51. Arguing in the same way, the probabilities that the third, fourth, fifth, sixth, seventh, eighth, ninth, and tenth cards are not aces are 46/50, 45/49, 44/48, 43/47, 42/46, 41/45, 40/44, and 39/43. The probability that, of all 10 cards, none is an ace is the product of those fractions, (48/52)(47/51)(46/50)(45/49)(44/48)(43/47)(42/46)(41/45)(40/44)(39/43).
b) A "maximum of three aces" means "0 aces or 1 ace or 2 aces or 3 aces". The probability of 0 aces is the calculation above. For one ace we can start with the assumption that the ace is the first card drawn. The probability the first card is an ace is 4/52. Then the probability the second is not an ace is 48/51, then 47/50, etc. The probability the first card drawn is an ace and the next nine are not is (4/52)(48/51)(47/50)(46/49)(45/48)(44/47)(43/46)(42/45)(41/44)(40/43).
Doing the same kind of calculation for the case that "the second card is an ace, all others not aces", is exactly the same. And, in fact, the probability the ace is in any given position, the other not aces, is exactly the same- the numerators and denominators are exactly the same, the numerators just in a different order. Since there are 10 places the ace could be multiply that by 10: 10(4/52)(48/51)(47/50)(46/49)(45/48)(44/47)(43/46)(42/45)(41/44)(40/43).
Similarly the probability the first two cards are aces and the other 8 not is (4/52)(3/51)(48/50)(47/49)(46/48)(45/47)(44/46)(43/45)(42/44)(41/43). But there are 10!/(2!)(8!)= 45 ways those two aces can appear in 10 cards so the probability of 2 aces and 8 non-aces in any order is 45(4/52)(3/51)(48/50)(47/49)(46/48)(45/47)(44/46)(43/45)(42/44)(41/43)
The probability the first three cards are aces and the other 7 are not is (4/52)(3/51)(2/50)(48/49)(47/48)(46/47)(45/46)(44/45)(43/44)(43/44)(42/43). But now there are 10!/3!7!= 120. The probability of three aces and 7 non-aces in any order is 120(4/52)(3/51)(2/50)(48/49)(47/48)(46/47)(45/46)(44/45)(43/44)(43/44)(42/43).
The probability of "a maximum of 3 aces" is the sum of those.
"At least one ace and at least one face card" is best done by calculating the probability that does NOT happen, then subtracting from 1. So first calculate the probability of "no ace", then calculate the probability or "no face card" and add. But that would include "no ace" and "no face card" twice so you need to subtract of the probability or "no ace and no face card" before subtracting from 1.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
