In summary, In this homework, we looked at a system that oscillates at a particular frequency, and we found that the probability of finding a particle at a certain point is proportional to the cosine of the frequency. We also showed that if we integrate over an interval including the point, the probability density function is maximized.
SSDdefragger
We know that after long run of simple mass-spring system, there should be a probability of finding the mass at certain points between -A and A.. Obviously in probability of finding the particle near A or -A is higher than finding the particle at 0, because the speed is the highest at equilibrium point. We need $p(x)$, so that $p(x)$$dx$ is probability of finding the point between $x$ and $x+dx$.
Given values:
E - energy of the system
m - mass of the point
k - spring constant obeying Hook's law
Standard mass-spring equations. We basically know everything about the system
[itex]\int_{-A}^{A} p(x)dx=1[/itex]
Particle has to be somewhere!
I thought that it doesn't matter if it's sinusoidal or cosinusoidal oscillation, we can choose any. Meaning that we know everything about system, but still I can't move physical knowledge of the system into mathematical language of statistics.
The probability density at location ##x## should be proportional to the reciprocal of the velocity at that location, since it is proportional to the time spent in the incremental spatial area around that location. To be able to integrate wrt ##x##, you'll need to express the velocity in terms of ##x## rather than in terms of time ##t##.
The integrand blows up at the extreme points because of the zero velocity, but I think it is still integrable.
adnrewkirk, if the integral of 1/cosx blows up that means it is not correct answer. I actually thought that it is directly proportional to 1/v or 1/(v^2) but it is not the case, the integral does not make sense or it blows up using this logic.
Why do you feel that?
It's perfectly valid to have a prob density function that is unbounded and 'hits infinity' at isolated points. What matters is that the integral over intervals including such points exists, and that is indeed the case here.
Given values:
You need some type of underlying probability model. One "reasonable" model might be that we choose the time t at random and see what is x(t) at that time. Of course, we cannot have a uniform random variable on the whole real line, but we could look at a large, finite interval ##[0, M]## and suppose that the time is a random variable ##T## on that interval. Then, given a distribution of ##T## we can perform the usual type of change of variable in probability theory to obtain a probability distribution of ##X##. In fact, if we let ##M## be an integer multiple of the period, we can obtain nice results; in fact, by periodicity, we might as well just restrict ourselves to a single period. I am going to re-scale time so that the motion is particularly simple. So, we look at the periodic motion ##x(t) = A \sin(2 \pi t), 0 \leq t \leq 1##. Let ##T \sim U([0,1]) ## be a uniformly-distributed random variable (time) on the interval ##[0,1]## and let the random variable ##X## be the function ##X = A \sin( 2 \pi T)##. We can perform a standard change-of variable computation to obtain the probability density of ##X## as
[tex] f_X(x) = \frac{1}{\pi} \frac{1}{\sqrt{A^2 - x^2}}, \; -A < x < A [/tex]
This satisfies the condition ##\int_A^A f_X(x) \, dx = 1##, and it also satisfies your intuitive property of being maximal near the endpoints.
Likes Privatecroat and SSDdefragger
FAQ: Probability density function of simple Mass-Spring system.
What is a probability density function?
A probability density function (PDF) is a mathematical function that describes the probability of a continuous random variable falling within a particular range of values. It is used to represent the distribution of a random variable and can be used to calculate the likelihood of a particular outcome occurring.
How is the PDF used in a simple mass-spring system?
In a simple mass-spring system, the PDF is used to describe the probability of the mass being in a particular position at a given time. This is important because the position of the mass is constantly changing due to the motion of the spring, and the PDF allows us to calculate the probability of the mass being in a certain position at any given moment.
What factors affect the shape of the PDF in a mass-spring system?
The shape of the PDF in a mass-spring system is affected by several factors, including the stiffness of the spring, the mass of the object, and the initial conditions of the system. These factors determine the behavior of the system and can result in a variety of different PDF shapes.
How is the PDF related to the concept of energy in a mass-spring system?
The PDF is related to the concept of energy in a mass-spring system through the concept of potential energy. As the mass moves within the spring, it gains and loses potential energy, which is directly related to its position within the system. The PDF helps us understand the distribution of this potential energy within the system.
What are some applications of the PDF in real-world scenarios?
The PDF of a mass-spring system has many real-world applications, including in the fields of physics, engineering, and finance. It can be used to model the behavior of various systems, such as a swinging pendulum or a vibrating bridge, and can provide valuable insights into the likelihood of certain outcomes in these systems.
