Probability Density Functions: Transformation of Variables
In summary, the conversation discusses using probability transformations when the transformation function is not a one-to-one function over the defined domain. This involves calculating the Jacobian determinant and considering multiple disjoint intervals in the domain of integration. The CDF can be expressed as a series of differences of CDF values with respect to the original variable, and the PDF can be obtained by differentiating the CDF with respect to the transformed variable. However, this approach can become complicated when working with non-monotone transformations.
Master1022
611
117
If we have ## p(x) = c(x+1)^2 (1 - x) ## where ## -1 \leq x \leq 1 ## and we have a variable transformation ## Z = X^2 ##, then find ## p(z) ##
Probability transformation
Hi,
I have a question about probability transformations when the transformation function is a many-to-one function over the defined domain.
Question: How do we transform the variables when the transformation function is not a one-to-one function over the domain defined? If we have ## p(x) = m(x+1)^2 (1 - x) ## where ## -1 \leq x \leq 1 ##, where ## m ## is a constant, and we have a variable transformation ## Z = X^2 ##, then find ## p(z) ##
Context attempt:
I was reading some lecture notes where all it says is: "if the transformation function ## h(x) ## is not one-to-one, then we use a more complicated method".
So I know that usually when we go from ## x ## to ## z ##, then we need to consider the Jacobian determinant ## | \frac{\partial x}{\partial z} | ##. For the example above, then that becomes:
[tex] p(z) = m(\sqrt{z} + 1)^2 (1 - \sqrt{z}) \cdot \left|\frac{\partial x}{\partial z} \right| = m(\sqrt{z} + 1)^2 (1 - \sqrt{z}) \cdot \frac{1}{2\sqrt{z}} [/tex]
but this exactly what was done for the situation where the transformation function was 1-to-1 over the domain defined.
For a discrete system when we have a transformation, then we might have something along the lines of:
[tex] p(Z = z) = \sum p(Z = X^2, X = x) = \sum p(Z = X^2|X = x) p(X = x) [/tex]
but I am confused on how I can utilize this methodology for the continuous case.
Thank you in advance for any help.
I think this works better (conceptually) in the CDF for the system of which the PDF is the derivative (with some generalizations) of the CDF. Also CDF's can be agnostic about "continuous" vs "discrete" vs "mixed" distributions.
Where ##z = \zeta(x)## is a "reasonable" mapping (e.g. piecewise analytic).
[tex] P(Z\le z) = \int_{\forall x: \zeta(x)\le z} f(x) dx = \int_{\forall x:\zeta(x)\le z} \frac{d}{dx} P(X\le x) dx[/tex]
where ##f## is the density function in ##x## and the derivative inside the integral is generalized to yield delta functions for steps. The problem with the general case is, of course, working with variable transformations which are not monotone increasing or monotone decreasing i.e. not continuously invertible.
When that is the case your domain of integration for certain z-values will be multiple disjoint intervals (including single points as zero-width closed intervals) where both boundaries will depend on z.
Then when you differentiate the CDF to get the PDF (w.r.t. z) you're going to have to differentiate several (potentially infinitely many) boundaries of the resulting integrals. But, in the end you can express the CDF w.r.t. z as a series of differences of CDF values w.r.t. x. E.g. let ##\{[x_1(z),x_2(z)], [x_3(z),x_4(z)], \ldots\}## be the set of intervals where ##x## satisfies ##\zeta(x)<z##. Then:
[tex] P(Z\le z) = \int_{x_1}^{x_2} f(x)dx + \int_{x_3}^{x_4} f(x) dx + \ldots = F(x_2)-F(x_1) + F(x_4)-F(x_3) \ldots[/tex]
where ##F(x) = P(X\le x)## is the CDF in ##x##. To get the PDF you then differentiate w.r.t. ##z## recalling each of the ##x##'s depend on ##z##.
I don't think you can get simpler and more direct than this without making simplifying (or at least specifying) assumptions about the change of variable.
[edit: Here I implicitly assumed continuity and you'll have to be more careful with open vs closed intervals in the discrete or partially discrete cases.]
[edit2: But then you should just work with sums in the discrete case and break mixed cases into sums of a discrete and a continuous distribution.]
Thank you very much @jambaugh ! I have some follow-up questions as I don't think I understand everything in the post.
Okay, understood (I think)
Sorry, I don't quite get why this is the case. Could you perhaps explain why? So for the transformation function ## \zeta(x) ## which is many-to-one, then we need to split the function up into different regions? (e.g -1 to 0 and 0 to 1)?
jambaugh said:
Then:
okay thanks. I am still slightly confused about what steps I should do to tackle this problem. Should I:
1) Find the CDF of the original distribution
2) Change the variables to get CDF in terms of Z - I still am not sure how to do this in practice here
3) Then differentiate that to get pdf in terms of z
Thanks in advance
Here you can use the fact that [itex]0 \leq a^2 \leq X^2 \leq b^2[/itex] if and only if either [itex]-|b| \leq X \leq -|a|[/itex] or [itex]|a| \leq X \leq |b|[/itex]. Then [tex]
P(X^2 \leq z) = \int_{a^2}^z\,f_{X^2}(z)\,dz = \int_{-z^{1/2}}^{-|a|} f_X(x)\,dx + \int_{|a|}^{z^{1/2}} f_X(x)\,dx[/tex] for [itex]a^2 \leq z \leq b^2.[/itex]
Likes etotheipi
Related to Probability Density Functions: Transformation of Variables
1. What is a probability density function (PDF)?
A probability density function (PDF) is a mathematical function that describes the probability of a random variable taking on a specific value or falling within a certain range of values. It is used to represent the distribution of a continuous random variable.
2. How do you transform variables in a PDF?
To transform variables in a PDF, you can use the change of variables formula. This involves substituting the original variable with a new variable and then solving for the new PDF in terms of the new variable. This allows you to convert a PDF from one set of variables to another.
3. What is the purpose of transforming variables in a PDF?
The purpose of transforming variables in a PDF is to simplify the analysis of data and make it easier to understand. It can also help to identify patterns and relationships between variables that may not be apparent in the original form of the data.
4. Can you provide an example of transforming variables in a PDF?
Yes, an example of transforming variables in a PDF is transforming a normally distributed variable into a standard normal variable. This is done by using the z-score formula, which converts the original variable into a new variable with a mean of 0 and a standard deviation of 1.
5. Are there any limitations to transforming variables in a PDF?
Yes, there are limitations to transforming variables in a PDF. The transformation must be a one-to-one function, meaning that each value of the original variable maps to a unique value of the new variable. Additionally, the transformation should be continuous and differentiable to ensure the accuracy of the new PDF.
