Probability density of a 1-D Tonk Gas
GravityX
Show that the probability density of an arbitrary ##y_i## is: ##p(y_i=y)=\frac{N(L_f-y)^{N-1}}{L_f^N}## for ##0\leq y \leq L_f##
none
It is a 1D Tonk gas consisting of ##N## particles lined up on the interval ##L##. The particles themselves have the length ##a##. Between two particles there is a gap of length ##y_i##. ##L_f## is the free length, i.e. ##L_f=L-Na##.
I have now received the following tip:
Determine the relative size of the slice through location space defined by a given ##y_1##. Visualize the case ##N=2##.
Is the following meant by relative size? ##\frac{y_1}{L}##
Unfortunately, I can't do anything with the tip because I don't know what exactly I have to do.
GravityX said:
Homework Statement:: Show that the probability density of an arbitrary ##y_i## is: ##p(y_i=y)=\frac{N(L_f-y)^{N-1}}{L_f^N}## for ##0\leq y \leq L_f##
Relevant Equations:: none
My guess is that location space means an N-dimensional cube of side Lf. The locations of the particles are then representable by a point in the cube.
For two particles, you have a square. The positions of the particles, measured from one end, are x, y. By choosing y>x, you have only a triangle to consider, and their separation is y-x. So in the triangle, fix the value of y-x and determine the line of points (x,y) which satisfy that. How long is the line, as a function of y-x?
