Probability: Dice Game between 20- and 12-sided dice with re-rolls
The discussion revolves around calculating the probability of winning in a dice game between a player with a 12-sided die and another with a 20-sided die, each having two rolls and the option to stop at either roll. There is debate over whether the second roll affects the outcome, with some arguing that it does not influence the probabilities since both players would employ similar strategies. The calculations presented suggest that the second roll does matter, particularly for the 20-sided die, which can improve its chances significantly by re-rolling low numbers. The conversation emphasizes the need for a strategic approach to determine optimal re-roll thresholds for both players. Ultimately, the importance of careful analysis over casual opinions in solving such probability problems is highlighted.
Master1022
One person has a 12 sided die and the other has a 20 sided die. They each get two rolls and they can each chose to stop rolling on either one of the rolls, taking the number on that roll. Whoever has the higher number wins, with the tie going to the person with the 12 sided die. What is the probability that the person with the 20 sided die wins this game? Assume the players cannot see the others' roll.
Probability
Hi,
I was reading around and found this problem. I have seen some discussion about the solution (but nothing verified) with some disagreement.
Problem: One person has a 12 sided die and the other has a 20 sided die. They each get two rolls and they can each chose to stop rolling on either one of the rolls, taking the number on that roll. Whoever has the higher number wins, with the tie going to the person with the 12 sided die. What is the probability that the person with the 20 sided die wins this game? Assume the players cannot see the others' roll. (note this is asked as an interview question, so resources available are limited)
My question: does the re-roll matter in terms of calculating the answer? Some people seem to think that: "Then, part of the trick is realizing that the second roll doesn't matter. Whatever the strategy is for the second roll, both parties will use it and therefore, their chances of winnings are the same. "
If that is the case, I can understand a way to get to the solution. Let ##W## represent the event that the person with the 20-sided die wins the game. Then,
$$ P(W) = P(W|\text{20-side die} \leq 12)\cdot P(\text{20-side die} \leq 12) + P(W|\text{20-side die} \geq 13)\cdot P(13 \leq \text{20-side die} \leq 20) $$
where ## P(W|\text{20-side die} \geq 13) = 1 ## and ## P(W|\text{20-side die} \leq 12) = \frac{\frac{144 - 12}{2}}{144} = \frac{11}{24} ## and these can lead to the answer. However, I don't get that assumption about the second roll.
Any help would be greatly appreciated.
I think you should be able to do a lot more analysis than this. I don't see the argument about the second roll being irrelevant. Consider, for example, a 20-sided die against a two-sided die. The second roll is of little use to 2-sided die, but much more use to the 20-sided die, who can practically guarantee a win by re-rolling whenever he gets a 1 or 2.
So, that argument doesn't hold up in my view.
Next, the odds should be easy to calculate for one roll.
Finally, each player must choose a number below which they will re-roll. The odds will vary according to these two decisions, so I imagine we are looking for an optimum strategy for both players.
You could calculate (or simulate using Python) all the possible strategies for both players and see what you get.
Likes SammyS and Master1022
The better trick is not to trust opinions of random commentators online.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
