MHB Probability distribution of a RV is a function of another RV
A random variable I has a countably infinite sample space with a probability distribution dependent on another set of independent and identically distributed random variables Xi, uniformly distributed in [0,1]. The probability distribution is defined mathematically, and the mean of I is expressed as a sum involving P(I=i) multiplied by i. Bincy questions whether the average can be calculated through multiple integrations and seeks simplification methods. Ultimately, it is confirmed that if the probability distribution of a random variable X is a function of another random variable Y, then X is also a function of Y, leading to the conclusion that the mean of I is N, based on geometric distribution principles.
bincy
Dear friends,
I have a Random Variable I. Sample space of I is from 1,2,3... inf(countably infinite). It's probability distribution P(I=i) is a function of another set of Random Variables Xi's, which are uniformly distributed in [0,1]. These Random variable are iid. I have to find out the mean of I. The mean of Xi's is 0.5 for every i.
I am giving the probability distribution of i below.
[math]P(I=i)=\left\{ \prod_{j=1}^{i-1}\left(1-\left(N*x_{j}*\left(1-x_{j}\right)^{N-1}\right)\right)\right\} N*x_{i}\left(1-x_{i}\right)^{N-1} [/math]
The average of I is [math]\sum_{i=1}^{inf}P(I=i)*i [/math]
Can anyone give any idea to solve this problem?regards,
Bincy
---------- Post added at 16:41 ---------- Previous post was at 15:13 ----------
[math] \int_{0}^{1}\int_{0}^{1}.....\int_{0}^{1}\left\{ \prod_{j=1}^{i-1}\left(1-\left(N*x_{j}*\left(1-x_{j}\right)^{N-1}\right)\right)\right\} N*x_{i}\left(1-x_{i}\right)^{N-1} *i [/math]
Is it the actual average? If so, how to simplify it? Here integration is infinite times.regards,
Bincy
---------- Post added at 17:44 ---------- Previous post was at 16:41 ----------
I would like to add one more general point and kindly seeking the confirmation from you.
That is,
If the prob distribution of a RV X is a fn of another RV Y, X itself would be a fn of Y.
Mathematics news on Phys.org
The answer(mean of I) is N since the probability of success in the 1st, 2nd, 3rd and so on is geometric with parameter 1/N. Ignore my 2nd and 3rd posts
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
