MHB Probability: Find the number of ways to form 4-digit numbers >3000
To find the number of distinct 4-digit numbers greater than 3000 using the digits 2, 2, 3, 3, 3, 4, 4, 4, 4, the first digit must be either 3 or 4. If the first digit is 3, the remaining digits can be selected from 2, 2, 3, 3, 4, 4, 4, resulting in 25 valid combinations. If the first digit is 4, the remaining digits yield 26 valid combinations. Therefore, the total number of distinct 4-digit numbers greater than 3000 is 51. The calculations confirm the solution is accurate.
Joe_1234
Please help me solve this,
Given digits 2,2,3,3,3,4,4,4,4, how many distinct 4 digit numbers greater than 3000 can be formed?
Thank you
Mathematics news on Phys.org
What have you tried, and where are you stuck?
2×3×3×3=54, is this correct sir? I am confused since 51 is the key answer
The first digit is either 3 or 4. So, let's consider each case separately:
(1) First digit is 3:
Then the rest of the numbers must come from the list: 2, 2, 3, 3, 4, 4, 4, 4
Therefore we may choose any 3-digit sequence except 222 and 333 for the rest of the digits. This shows there are:
$$N_1=3^3-2=25$$
numbers in this case.
(2) First digit is 4:
Then the rest of the numbers must come from the list 2, 2, 3, 3, 3, 4, 4, 4
Therefore we may choose any 3-digit sequence except 222 for the rest of the digits. This shows there are:
$$N_2=3^3-1=26$$
Hence, the total number is:
$$N=N_1+N_2=51$$
$$N_1=3^3-2=25$$
$$N_2=3^3-1=26$$
$$N=N_1+N_2=51$$
Thank you sir
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
